Question about Orange SPV M2000 Pocket PC
Adding a sound for alarm use
Need help Ipaq rx5900 adding a sound for alarm use
    An expert whose answer gotĀ voted for 100 times.
  • 146 Answers
Hi there
connect your PDA with activesynk and right click on the icon near the clock and click on Explore, then click on the windows and the click on the ring folder...past the sound file here from your computer and close the mobile explore window..
now set the alarm and click on the BELL icon on the pda and from here you can select the sound file for alarm.
all the best
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 02, 2008
Copy the sound you want into the windows folder.
Posted on Oct 20, 2007
Problem event PnPDeviceProblemCode The problem
which kind of software do u used? Are driver compatible with ur OS?
May be they are not compatible..
Nov 24, 2009 | Computers & Internet
Alarm not sounding & notifications not displaying +- syncing
Hi. First of all, I think the hard reset is not the first solution, but it's the last and the absolute solution. But in case if it is needed you can perform it by: The phone buttons + reset & power = hard reset. Firstly, tap the Start and the Settings. There, find the Sounds & Notifications. Ensure that the first 3 of the checkboxes are checked. And select the second tab to configure your notification sounds and vibration settings. After you've done these, you can try to set an alarm and check if your PDA notifies you. If not, you can also give a try to this free alarm application ( for your PDA. If none of these work, you can try to hard reset your device, but you should backup all your data before a hard reset since all the data will be lost after a hard reset. Hope this helps.
Apr 21, 2009 | HP iPAQ hw6915 Smartphone
My ipaq hp pda Rx3115 does not have the right time as my clock does how do i change the time?
Start Menu
--> Settings
--> System
--> "clock & alarms"
There you go. You can even set an alarm. :)
Apr 04, 2009 | HP iPAQ RX3115 Pocket PC
How do i do a hard reset on my hp ipaq rx5900 gps. its frozen
To my knowledge, there is a reset hole along with voice record button and an SD/MMC card expansion slot on top of the unit. Use the stylus to lightly press the reset button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 02, 2008 | GPS
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
Ringtone change
The ipaq is not playing large files. It only makes a small beep sound if the wav file is big. I am using a wav file of less than 800 k and it works.
Nov 03, 2007 | HP iPAQ hw6515 Pocket PC
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
Same IPAQ -New Computer
you should just be able to sync it with the new computer. The data from the IPAQ will be synced to the new computer.
Sep 14, 2005 | HP iPAQ HX2755 Pocket PC
Is an audible alarm software available?
I'm not sure of the HX4705's capabilities to sound multiple alarms, but I have downloaded a free alarm program called Wolfclock to my iPaq rz3715 which I use for the exact same reasons (meetings, wake up, take medication...) Try this link:
Sep 14, 2005 | HP iPAQ HX4705 Pocket PC
Connecting RX3115 to Laptop w/ WiFi
you have to configure an ad-hoc connection between ipaq and pc if no router. otherwise, simply connect to the router and run activesynch
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
Orange SPV M2000 Pocket PC Logo
98 people viewed this question
Top Orange Computers & Internet Experts
Computer Repairing
Computer Repairing
Cosma Papouis
Cosma Papouis
Sandy Moore
Sandy Moore
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
