Question about Lasko 3720 Floor / Box Fan
Bad ac fan capacitor cant get one right now can I bypass until morning
Why is fan not working on outdoor unit?
Very common problem is the capacitor goes bad. The capacitor stores energy that starts the fan spinning. Turn ac on and take a long skinny screwdriver, or straighten a metal cotehanger and slide through fan cover and give it a little push, if it starts spinning indicator the capacitor has gone bad. They are fairly inexpensive for most ac units..and are pretty easy to replace. If you do replacethe capacitor is located in compartment with a metal cover on the side of outdoor unit. Be sure to kill power to ac before replacing, also the capacitor stores electricity..it can zap you if you touch the top of capacitor where plug connections are. Take a screwdriver and touch across the connection points and discharge the capacitor for safe handling..here are some images of what the capacitors look like..
25872686-lssthgpi25gedqz0c32oowfn-2-2.png If capacitor is bad and you replace, I suggest taking a picture of the capacitor while its connected in case you forget where the wires gp
Sep 19, 2015 | Heating & Cooling
Coleman ac compressor quit working
The black plastic capacitor is the compressor start capacitor, it is only in the circuit until the compressor gets up to speed. The black box is the start relay, it stays closed until the compressor gets up to speed the opens taking the start capacitor out of the circuit. The wires should go from it to the small metal round capacitor and the black box.
You can Ohm out the start relay, it should be closed between Terminals 1 and 2 and the coil is from 2 to 5. You can also check the 2 capacitors, you need a Volt Ohm Meter that has a capacitor testing scale. The microFarads should be on the capacitors you will need to cut the bleed resistor on the start capacitor before testing it.
Jul 18, 2013 | Coleman Mach III Air Conditioner
Outside unit fan does not kick on just hums and you can hear a clicking like a breaker kicking on and off.
thats a bad starting capacitor .. the capacitor is a metal rounded box about 3 inch x2 inch .. it has wires going into the fan and into the compressor .. its usually mounted near or on the compressor ... there are usually 2 capacitors in one container ..one for the compressor and one for the fan .. if the capacitor is bad then the fan and/or the compressor will just buzz but wont start .. the motor will get hot until a thermal breaker shuts off the power .. then when it cools it will turn back on and try again ... if you allow this to continue it can damage things ... the capacitors don't cost much .. you can remove your old one safely as long as power is turned off at the circuit breakers for the AC ... note where the wires go .. usually they have "pull off" connectors that are different sizes so you cant mix them up .. take the old capacitor with you to an air conditioning parts house . or get your AC make and model number and contact the manufacturer for a replacement capacitor.. you can also take all the numbers off the capacitor and order a replacement off the internet .. replace the capacitor and it should fire right up ... if you call a service man .. tell him that you suspect the starting capacitor .. that way he will bring a selection with him or he might have them with him anyhow but if he knows your make and model number then he can bring an exact replacement .. ..
Aug 15, 2010 | Carrier Heating & Cooling
Carrier AC fan not working right
it sounds like the capacitor is shot there is usually a duel capacitor one side is for the compressor and the other side is for the condensor fan motor if it is bad the motor will over heat and turn off on internal overload
Aug 25, 2009 | Heating & Cooling
I have an intertherm central air unit in my mobile home that does not change fan speed when I click the fan speed switch. I've checked the fan relay which is good and energized in the ac mode which should...
You may ahve a bad switch but sometimes when they are worked on the servicrman bypasses the switch. Fan speeds are color coded black high blue med yellow med high and red low. Just for your info. Russ
Aug 16, 2009 | Heating & Cooling
Carrier AC Model No. 38CKS fan not spinning
You have bad cccccccccapacitor in your outside unit. Not hard to replace but you need to find someone to sell you one It should say 45 5 or 50 5 on the side of the capacitor. You can also call a service tech about 150 for the repair. Rus Carrier Dealer 45 years
Jul 18, 2009 | Heating & Cooling
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Fan
you need to have whole ac serviced do everthing at once so it works right
Jun 02, 2008 | Weather King 10AJA4801AH Air Conditioner
Lasko 3720 Floor / Box Fan Logo
27 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
