SOURCE: Bluetooth Pairing
i have up loaded blue tooth from a cd bu i can not get a connection what is the problem it was working on my last pc
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
SOURCE: My LG cookie is not able to detect the Nokia Bluetooth headset
Sorry if you have done this but let's see if we can get you connected!
On your Nokia headset press and hold the multi-function key for roughly 8 seconds. Your green light will begin to flash quickly. Your Bluetooth headset is now in pairing mode.
Now using your LG Cookie, press Menu > Settings > Bluetooth > Search
Once found, you will need to type the pass code which is normally set as four zeros (0000).
You should now be connected.
We hope this helps!
SOURCE: its a bluetooth headset..!! the
Hi you can try 0000(zero,s) or 1111 alot of bluetooth headset use them has default.
regards
SOURCE: I cannot pair by Nokia
bluetooth headset BH-108 not connect and not pair to NOKIA_N8
king give the solution as soon as possible.
