Question about Gateway FPD1530 15" Flat Panel LCD Monitor
Its dead There was a power surge,it went off. opend up ,and replaced blown up fuse,but big capacitor bulged up not rerplaced ,but it worked .Later it went dead ,opend up again the power pack is off.Mosfets ok i suspect ic DAP8A,but cannt get datasheet.any assistance?
TV went bang now no power
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on howto replace capacitors.
Oct 20, 2014 | Samsung Televison & Video
Runco CL710 projector. Had power outage and projector won't turn on. Project was plugged into surge protector. Surge protector is working, green light is on. Checked all electrical breakers, they are...
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video for this.
Aug 25, 2013 | Runco CL-410 Multimedia Projector
Good Morning, Everyone!!!! I have an NEC CT 2020 A TV that recently went out due to a power surge. Is it better to replace the fuse on this model or buy a new tv alltogether????
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout in solving the problem...
Jun 14, 2011 | Televison & Video
I cant get tv to come on stand by light wont come on
You have to check main power socket of the wall, if it okay or not , then procedure to the power plug of the television, it has a fuse check if it blown or not, if not you have to open the back cover of the television to on the power board, if the fuses are blown or not ,if otherwise the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will helpout to rectify the fault..
May 17, 2011 | Televison & Video
Power went out and now TV won't turn on
Good day,
This is a type of fault that is associated with the power board, you have to open the back cover and check for blown fuses, if found replace with the same rating,because this is the common cause of the type of fault, if otherwise the power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem and do take caution in handling the television because there is high voltages in the power panel board of the television....
May 13, 2011 | Sony KDL32EX600 32 in TV
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Will not power on
hello,
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
TV will not power on
Yes,power supply board have dead capacitors leakage problems.These capacitors useally bulge up or burst open.U know how to solders?Look in the power supply board rerplaced these capacitors will solved the power problem.Or tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | SNK Magnavox 32MF338B27 32 in. LCD TV
Wega KV-32FS10 won't power up
not only one component might have been damaged! check for capacitors for bulging on their upper part! also check for open fusible resistors and power transistors for shorts
Dec 06, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
