Question about Viking VGBQ410-3RT Grill
Ignition switch does not click to ignite, battery is new
    New Friend:
Ignition or fuse relay under hood has gone had
Posted on Aug 02, 2017
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
If you do not hear a clicking sound then the ignition module may be bad.
Have a 99 Jimmy GMC when u hook battery up I can not get power to itintion switch fus box r inside if car period battery is good I mad sure of that
Do you know how to read a wiring diagram ? Go here http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter your vehicle info - year , make , model , engine etc... Under system click on electrical distribution , then under subsystem click on power distribution .Then click on search , six blue links will pop up , click on them one at a time . See where ignition switch gets it's power . The ignition B fuse 50amp located in the under hood fuse box, supplies B+ voltage to the ignition switch .Plus Ignition C an ignition A fuse's also power ignition switch .
Mar 13, 2016 | GMC Cars & Trucks
Ignition switch on dodge dynasty?
I had a similar problem years ago. As long as your dash lights come on, it's likely you can use an external pushbutton switch to run the starter. There are likely just 4 wires on the ignition switch. Power from the battery, and switched to:
accessories
main car stuff (dash lights, ignition, signals, etc)
starter.
splice in wires from battery and starter to new switch, and you're good to go. This worked for years on my old car.
Jun 01, 2015 | 1992 Dodge Dynasty
Truck will not crank. Previous owner installed crappy kill switch that initially started the problem.I by pass it and truck was running fine. Till the a ground cable came loose on the battery. There's...
It would be the ignition or those ignition wires because of the kill switch being poorly installed, id try tracing wires first and replace anything thats been cut/spliced into. if not change the ignition
May 12, 2011 | 1992 Toyota Pickup
We need to replace the ignition lock on a 2004 Grand Am.
The ignition switch is immediately behind and attached to the ignition lock cylinder. The ignition lock cylinder is where you place the key to start your vehicle. If you are having problems with your vehicle not starting and or turning the key, more than likely you need to replace the ignition lock cylinder. It is common for these to go bad in GM vehicles. To replace the ignition switch of Your car please get these instruments (Flat head screwdriver, Mechanic's gloves, Socket wrench with adapters, Lint-free cloth)and carefully follow the steps below:
  1. Disconnect the negative battery cable from the terminal of your Pontiac Grand Am's battery. This will ensure that you avoid the potential of electrocution as well as accidental inflation of the air bag. After disconnecting the battery, wait 15 minutes before performing any work on the car.
  2. Remove the three flat head screws from the steering column cover to access the ignition switch assembly. If the covers and interior parts of the steering column are dirty or dusty, try cleaning them with a damp, lint-free cloth.
  3. Depress the silver button on the column underneath the ignition switch if your key is still stuck in the lock cylinder. You will need to turn the key to the "Off" position and remove it in order to remove the rest of the ignition switch assembly.
  4. Remove the two connection bolts holding the ignition switch assembly into place. Disconnect the electrical connection tab leading to the ignition switch as well as the tab that sits behind the ignition switch once you slide it out from the steering column console.
  5. Clip the electrical connection tab to the new ignition switch for your 2004 Pontiac Grand Am and slide the ignition switch into place. You will need to have the new key in the ignition switch as you slide it into place and turned to the "Off" position. Once it matches the exact position of the previous ignition switch, rotate the key to the "On" position, and you should hear a click from a tab that extends from the bottom of the ignition switch and connects with the ignition switch housing on the steering column. Reconnect the electrical connection tab leading to the ignition switch.
  6. Reconnect the negative battery terminal and turn your car on to make sure that you have made all of the connections correctly between the steering column and the new ignition switch. Reinstall the steering column panel coverings.
Hope this helps. Thank You for using FixYa!!!
Jan 18, 2011 | 2004 Pontiac Grand Am
2003 pontiac grand am will not crank over no click from selinoid nothing,new battery and starter is good also ignition switch has been checked good.
Hi. Since starter and ignition switch has been change. Try looking at the battery and its physical connections. What i am seeing here is, there is no power going to the ignition to kick the starter. I provided you a link what needs to be checked for no starting issues. Please click here.
Sep 21, 2010 | 2003 Pontiac Grand Am
Click when trying to start
Sounds like battery and battery cables full of resistance and battery may need replacement or charging.
May 21, 2010 | 1995 Nissan Pathfinder
New Ignition Cylinder doesnt click in?
Lock Cylinder Functional
Removal
  1. NOTE: The following procedure applies to vehicles that have functional ignition switch lock cylinders (11582), lock cylinder keys are available for these vehicles or the lock cylinder key numbers are known and the proper key can be made.
    Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Turn ignition switch lock cylinder to RUN position.
  1. Place a 3.17 mm (1/8-inch) diameter wire pin or small drift punch in hole in lower steering column shroud (3530) under ignition switch (11572). Press retaining pin while pulling out on ignition switch lock cylinder to remove it from steering column lock cylinder housing (3511).
Installation
  1. Install ignition switch lock cylinder by turning it to RUN position. Insert ignition switch lock cylinder into steering column lock cylinder housing. Make sure ignition switch lock cylinder is fully seated and aligned in interlocking washer before turning ignition switch lock cylinder to OFF position. This will permit cylinder retaining pin to extend into steering column tube flange hole.
  1. Rotate ignition switch lock cylinder, using lock cylinder key, to ensure correct mechanical operation in all positions.
  1. Connect battery ground cable.
Apr 03, 2009 | 1995 Ford Taurus
1999 Toyota Corolla CE. For about 2 months, the engine does not start immediately. I need to turn the ignition key several times until it starts. Each time when I turn the key, a clicking sound happens...
it sounds like either your having a short at the starter or the ignition switch is bad, I am leaning towards the issue being the starter, usually when the ignition switch is going bad there will be no click,
Oct 06, 2008 | Toyota Corolla Cars & Trucks
Seems battery being drained
Q1. Engine will not start or is hard to start (Cranks OK) A1 -Ignition lock switch faulty -Ignition coil faulty -Power transistor faulty -Spark plugs faulty -Ignition wiring disconnected or broken -Spark plugs faulty Q2, Engine will not crank A2. Battery discharged Battery cables loose, corroded or worn out Transaxle range switch faulty (Vehicle with automatic transaxle only) Fusible link blown Starter motor faulty Ignition switch faulty Ignition lock switch faulty REMEDY Charge or replace battery Repair or replace cables Adjust or replace switch Replace fusible link Repair starter motor Replace ignition switch Replace ignition lock switch
May 20, 2008 | 2000 Hyundai Accent
Viking VGBQ410-3RT Grill Logo
173 people viewed this question
Top Viking Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Mike Hollander
Mike Hollander
Level 1 Expert
Are you a Viking Grilling Expert? Answer questions, earn points and help others
