Question about Frigidaire FGX831C Top Load Stacked Washer / Dryer
Hi, I am trying to help daughter-in-law get their
Hi, I am trying to help daughter-in-law get their frigidaire top load washer fws777ghs0 working after a recent move. When on the regular and delicate cycle, the washer fills and fills and drains and drains. I thought it must be a syphoning problem, but it doesn't appear to be the case, because it fills normally on the permanent press cycle. If we fill the tub on the permanent press cycle and move it to the regular cycle, the machine runs great....that is, until it gets to the rinse part of the cycle. Then the problem starts all over again. It fills and continually drains. Why would it work right in the permanent press cycle, but will not work in the regular and the delicate cycles?
  • Official Brand Answer
  • 4,342 Answers
Hello annp, thank you for your post! Based on the symptoms you are describing, it does sounds like a siphoning issue. Generally speaking, the drain hose should come up above the washer tub and please make sure the drain hose is not too deep in to the house drain pipe. The drain hose should only be submerged 4-8 inches into the house drain pipe. If correct, otherwise the unit might be experiencing a communication with the control board and water fill valve. At this point, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - please do not hesitate to reconnect.
Posted on Aug 02, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 29 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
  • 130 Answers
SOURCE: Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on May 07, 2009
prawinmv22
  • 106 Answers
SOURCE: Kenmore Front Load Washer, 417.44082400, will not
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Posted on Jun 12, 2009
  • 38 Answers
SOURCE: Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Posted on Sep 26, 2009
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
Motor wireing diagram for frigidaire GLET1031FS top load stacked washer/dryer
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
I understand that manufacturers often supply technical diagrams to service engineers only.
I can only suggest you go directly to the manufacturer's web site and try
Good luck,
John C
Feb 27, 2011 | Frigidaire GLET1031FS Top Load Stacked...
I am trying to find a part number for my Frigidaire Front Load Washer - Part No. FTF2140FS0. Can you help? the plastic door latch (I think it's called the Safety Door Lock) has broken off. We can't find...
Alisa hi hun this is shonna neeley out of ohio i just recently had same problem u did and had heck of time trying find parts for my washer is the same as your i will give you the link where to go to order your parts for that washer it help me out greatly when i went there been buying there every since anywhooooo help is on it way doll.
Replacement parts in Cabinet/top section of FRIGIDAIRE FTF2140FS0 Frigidaire/washer
copy and paste this let me no if it helps i,m on facebook as shonna neeley if you need my help cause i strugled getting help from anyone / on my washer and dryer..
Dec 13, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire top loader
hi thanks for your question. it would appear to me that the problem is with your lid switch would check that first try it and let me know thanks THE APPLIANCE DOC.
Aug 04, 2008 | Frigidaire CWS3600AS Top Load Washer
Open Questions:
Frigidaire FGX831C Top Load Stacked Washer / Dryer Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
