Question about Refrigerators
I have rafrigerator national japan NR-306 TE.the freezer is good working but the down storage do not give cooling.the tecnicent says,the inbuilt heater which heats the frost way of the pipe from freezer to down freege is not working & not replaceable, so kindly solve the solution.
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: the refrigerator is national "nr-302
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 17, 2011
I have national Refrigerator NR 422-TE-G 2 doors which I bought from Saudi Arabia. This worked very efficiently for may years but now it is has defrost problem. Ice goest filled in freezer due to which fan...
Remove power and defrost. Check heater element behind panels in back of freezer. With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 21, 2013 | Refrigerators
The refrigerator is national "nr-302
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 16, 2011 | Refrigerators
I have a national NR-302TE-X fridge for the past 4 months the fan in the freezer gets frozen and stops due to this the fridge does not cool and a lot of water is defrosed and there is water inside the...
dear
there is a temp, sensor in side the fridge that turn on a heater rod and stops compressor that melts the ice at back of freezer and fan.
or toy can open rear panel in side freezer and pure hot water (not boiling ) on frozen ice on condenser coils, this will help you for on week and then you have to repeat it again
you need a good tech person to solve that problem
hope toy under stand
?Adnan : eng-adnanpaul@hotmail.com
Nov 13, 2010 | Refrigerators
DEFROST TIMER FOR NATIONAL REFRIGERATOR NR-302 TE-G
the defrost timer have a motor inside it......it act as a watch, in every 8 hrs it defrost if the problem lies in it than you need to replace it as because it is not repareable
Jun 16, 2009 | Refrigerators
NATIONAL NR232-TE-X IS NOT MAKING ICE .
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdjdfh
Jun 05, 2009 | Hoover HCA454FK Bottom Freezer...
Refrigerator cooling fan freez so not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
gf
Dec 27, 2008 | Nokia 3230 Cellular Phone
Refrigerator not cooling
Dear friend,
ngfam at you service! happy to assist!
Whats the size , model number, and year of the fridge?
And i'll try to figure it out!
Dose it have a black grille of tubes running up and down the back that you may have bent in transport??
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
