Question about Haier MWM11100TW / MWM11100TB 1000 Watts Microwave Oven
My Haier Microwave Model # MWG10081BB1 stopped working. It just keep beeping and showing all number 4's on the keypad.
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
I HAVE A SAMSUNG MICROWAVE MODEL SMH8165ST KEEPS BEEPING SE
"SE" error on a Samsung made microwave means you have a shorting membrane keypad.
This is a pretty simple DIY repair.
You would need part number DE94-01806C which you can get for about $68 from the Pros here, our favorite supplier.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then unplug the keypad strip and move your board into the new frame. Be careful, because the display is made of glass.
Some connectors on the relays have a lock:
Jan 29, 2013 | Samsung SMH9187ST Microwave Oven
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
Jmc8100 built in over jmw8530cas. only button on touchpad that works is stop/clear. turn breaker off for 12 hours, can set clock, use once or twice come back in 5 minutes, and only stop/clear beeps. have...
You have a failing membrane keypad.
On some models, you have to replaced the keypad separately.
I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, you can replace the whole control panel frame, which comes with a new keypad already installed.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also get details there if you need more help with the repair.
Oct 15, 2011 | Jenn-Air JMC8100 Microwave Oven
Chefmate microwave P70D20AL-D4 beeping
After calling many numbers, I was put in contact with the manufacturer, Galanz Microwave, and was told that that beeping is due to a burned out part in the keypad that is not servicable. I, too, have this annoying model!
Jul 19, 2009 | Danby DMW1153 Microwave Oven
Microwave oven panel starting beeping from and doesn't work
You either have a shorted keypad or another problem with the control panel assembly.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 23, 2008 | Whirlpool Microwave Ovens
Tappan microwave
I think the membrane/button for the number 4 is stuck or broken. Due to the nature of a microwave my advice would be to entrust the work to a competant technician. Hope this helps.
Oct 01, 2008 | Tappan Microwave Ovens
Keeps beeping and shows F3 but keypad not working
Ya what the ????
Not shure what to tell you, first I would see if leaving unplug for a day would solve your problem, to me sound like main board is defective, also try by opening the door a closing it a couple of time, just in cass a switch is jam open.
Regards
bob
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Haier MWM11100TW / MWM11100TB 1000 Watts Microwave Oven Logo
21 people viewed this question
Top Haier Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Haier Microwave Oven Expert? Answer questions, earn points and help others
