Question about Shuttle Computers & Internet
I'm looking for the Shuttle FA76v1 Motherboard Jumper settings manual. My motherboard powers up, with no display. I have 2 x 1GB Ram sticks but when I have both sticks in at the same time ... I get 2 solid lights (1 red - 1 green) But when I use either stick in the slot closest to the cpu ... I get one solid green. I think its a bad RAM slot but still why cant I get a display or beeps .... ANYTHING >>>> PLEASE HELP
joey64
  • 209 Answers
SOURCE: Blue Screen/Motherboard/RAM Problems CT-7VJL KT-333
perhaps the memory is loaded and that is the reason why it is getting blue. have you tried cleaning your hard disk? have you tried removing some of your registries? we have softwares in the market, a registry dleaner, to defrag automatically once you scheduled, to fix your pc and so on and this is what i am using you don't have to worry for errors this is SYSTEM MECHANIC 4 PRO
Posted on Dec 19, 2007
Tel1
  • 14 Answers
SOURCE: Motherboard not recognizing RAM
If you're running XP SP2, that may be by design because of something Microsoft did in SP2.
Look at the following article for an explanation.
http://support.microsoft.com/kb/888137/
Posted on Dec 25, 2007
leecom72
  • 4806 Answers
SOURCE: My motherboard reads MS-6712 VER 10A. It has 3 RAM
The motherboard is a socket A (AMD) processor board
The board supports DDR400*/DDR333/DDR266/DDR200 SDRAM
You can install a 1GB module in each slot (except the one which is damaged) that means you have a maximum of 2GB, 1X1GB in each slot.
Regards.
Posted on Oct 01, 2009
byteguy
  • 2229 Answers
SOURCE: Hi, I have just purchased a new system and after
You could try another power supply. Otherwise, I'd say it's DOA
Posted on Dec 11, 2009
Testimonial: "I have tried 2 power supplies with it (one brand new) guess I should send it back. Thanks"
  • 1288 Answers
SOURCE: I have a msi k9vgm-v motherboard with 2g ram.put
If you are using a 32 BIt operating system the Ram that is recognised will only be 3GB, you need a 64 bit OS to read more than this.
Posted on Dec 30, 2010
Continuous beep motherboard will not boot
check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Mar 24, 2014 | HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775...
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
My shuttle mv42 doesnt accept ddr rams
Either change the motherboard to one that does support DDR RAM, or purchase the correct RAM (SDRAM or DDR2 or DDR3) that is compatible with your motherboard.
Apr 09, 2010 | Shuttle MV42N (SHUTMV42N) Motherboard
Have power but no display
Open cpu cover and Reconnect the RAM memory into the motherboard circuit.
Also check that RAM works fine.
If you have another ram try with it.
IF still same then you need to reset motherboard bios settings to default.
Check on motherboard you can fine 1 jumper near cmos cell set it into 2-3 pins then power up the motherbord 3 times then again put jumper in its original position.
Then all settings goes to defaults.
Feb 11, 2010 | ASUS P5VD2-MX SE Motherboard
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Hi, Computer does not start. "F" is displayed on Abit A17 GURU motherboard.
Here is my flow chart.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 05, 2009 | Abit A17 Guru Motherboard
My PC Won't Start
Short beeps are usually a ram error. Try reseatting the ram stick(s) and if more than one then try one at a time and in different slot combinations.
Failing that try resetting the bios via the cmos jumper on the motherboard.
Do all of above with power off at plug off course :)
Jan 04, 2008 | Intel Desktop Board D845WN Motherboard
Motherboard or cpu.
reseat the proccesor, check that hard drives have proper jumper settings and the memory stick and cmos battery are seated proper.
let me know
Nov 11, 2007 | Intel Motherboard
Memory upgrade - P4M80-M4
Maybe your RAM is not compatible with the motherboard just refer to instruction manual...
Nov 06, 2007 | Biostar P4VMA-M Motherboard
Computers & Internet Logo
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
