Question about Kenmore Refrigerators
Model #253.748124OK mfg in 09; but local repairman says "out of gas" and not worth fixing. What's a guy to do?
Where is fuse or fuses located
...Halt! Cease! and Desist!! NEVER try to Locate a part on your Microwave and "Fix" it Yourself!! You must have a Deathwish!!
... Even knowledgeable, qualified Microwave Repairmen have DIED trying to effect a Repair!! Such as THIS has already happened to my sister-in- law! They found the guy DEAD on their Kitchen floor!! ALWAYS call a reputable Microwave Repairman to perform any professional repairs for you!
Feb 28, 2015 | Daewoo Touch Control 09 Cu Ft Compact...
If I have to pay the price to get my PC. fixed then it's not worth fixing. Nancy Reyes
Would you pay to get your brakes fixed on the car? How about the washer, dryer, refrigerator or air conditioning in the house? It's much cheaper to fix a PC (If you have a honest repairman) than to buy a new one. Try the guys at: http://www.generalsystemsconsulting.com They fix it and ship it back UPS or FEDEX
Mar 18, 2012 | Computers & Internet
Have F09 fault code on dryer
I think the 09 code may be for the door switch. I have the Kenmore HE2 gas dryer that would turn off mid cycle and not turn on again. A repairman came to try to fix it. He thought the control board was the problem because there was a saved fault code for F-01 which is the control board. When he replaced the control board the same problem happened. He couldn't fix it. I went through the diagnostics and an "09" code comes up right after the saved F-01 code. The dryer failed the door switch test and it says an 09 code indicates the door switch is faulty. I haven't purchased a new door swtich yet to see if this will fix the problem. Good luck. Peter
Aug 06, 2010 | Washing Machines
No sound
I have a similar problem. After about 20 minutes, it begings to heat excessively, though it does not malfunction (i consider myself lucky).
Mar 19, 2010 | Philips HTS-3565 Theater System
Dishwasher started smelling funny like electrical smoke. I opened up the top by the digital read out and noticed one of the wires was charred and had been smoking. worth it to call repairman? or buy a new...
I would call a repairman or just cut out the bad spot in the wire and use a **** connector and splice in some new wire. Maybe a new connector because it may have been caused by a loose connection drawing heat due to arching. I doubt its a major issue however it may be worth it to call a repairman just in case because it could potentially be a fire hazard. It may even be a recall on the dishwasher I would check your model number through MFG to see if there were any recalls.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
I bought a used direct vent vermont castings radiance model 2600 set up for natgas. I have been trying to get it converted to propane, with no luck. All dealers are telling me that the conversion kit is no...
if you know a lot about it you could convert it your self....you need to get rid of the Propane regulator....you need a Natural Gas Valve and you need to change the orifices....should be stamped on the rating plate the size of orifice for natural gas....I wouldn't recommend you do it yourself unless you have a license....or as I said know a lot about it...I wouldn't have a problem doing it in my own house...however you run into Insurance implications should anything happen if it's not an approved kit from the mfg.
Oct 19, 2009 | Heating & Cooling
Kenmore Coldspot Model 106 9557651 stopped cooling and freezing. Mfg date is 09/95.
please make sure that the electricity supply to the unit is in order. after that check wether the thermostat is in working order and if the compressor is running. If everything is in order tou have a gas leak and the unit must be charged with gas.
Aug 07, 2009 | Refrigerators
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
I received a Gas heating system from my dad and would like to know if I can switch it from Natural to propane gas. my model # RFN28TA.
Most furnaces come from the factory set for natural gas. If you contact the manufacturer to find the local distributor for that particular unit . you should be able to order a propane conversion kit. The kits are very easy for a trained heating guy to convert. A good handy man should be cable to do this changeover. BUT the manometer that is needed to properly calibrate the gas valve is not worth the purchase price for one application. I recommend that you use a trained heating guy.
Jan 12, 2009 | Heating & Cooling
Dak gelatisimo machine broken gears
I just helped a problem similar. It is possible to get a repair man and fix it. Get a hold of a repairman at www.repairman.org. I do not know the number but i'm shore it is on that website.
Nov 25, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Refrigerators Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
