Question about Echo Gas Blower 162 MPH 450 CFM Blower PB500T
Echo pb500t blower running lean 50:1 ratio - Echo Gas Blower 162 MPH 450 CFM Blower PB500T
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
Posted on May 26, 2009
wilsodfarm
  • 986 Answers
SOURCE: what is the gas;oil ratio for the echo 403T backpack leaf blower.
50 to 1
Posted on Nov 01, 2009
taran_2005
  • 10515 Answers
SOURCE: what is the correct oil to gas ratio for an Echo
Fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil.
Thanks!!
Posted on Nov 04, 2009
Testimonial: "Very prompt answer."
dontbother10
  • 2220 Answers
SOURCE: pb1000fuel to oil mix ratio for echo
New Echo manuals say "50:1 for all engines regardless of what is printed in manual."
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 09, 2009
  • 198 Answers
SOURCE: First time to add gasoline, I am not sure how to
50:1 means 50 parts gas to 1 part oil
you can mix a quart of gas with 1.5 oz of 2 sroke oil
Posted on May 07, 2010
What happens if you use 40:1 fuel to oil mix in a 50:1 echo pb251 leaf blower engine?
it is always better to use to much oil than not enough, using not enough will cause major damage to the engine. The oil in the gas mix is what lubes the cylinder/rings against the cylinder walls. 40:1 is way lean of oil for a 50:1 mix engine
Aug 12, 2014 | Garden
What's mis ratio for ECHO PB-400E blower
Two very good answers, if you go to use the 50:1 ratio you will probably not be wrong most new stuff mixes with the 50:1 ratio these days if your not comfortable mixing the gas, Menards has premixed can for sale, as do most of the big box stores. Very good for novice mixers who don't want to keep alot of fuel around and let it go bad. Great alternative to mixing!
Jun 21, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
Echo pb500t stallas when choke is opened
might check the exhaust port and muffler spark screen
Jul 19, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
Echo pb500 only runs with choke open
I'm not to sure about the question. But you say it runs with the chock open. Your engine will only run with the chock open. Can you clarify?
Feb 27, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
What fuel does my Echo pb500H use??? 2 stroke oil gas mixture????
2 stroke means that it is a gas mixture. 4 stroke means that there is no gas oil mixture.
Fuel is VERY flammable. Use extreme care when mixing, storing or handling, or serious personal injury may result.
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Do not forget to rate the answer, Thank-you
Jan 02, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
First time to add gasoline, I am not sure how to mix oil and gas for ECHO PB-2100 ratio 50-1
May 06, 2010 | ECHO, Inc. PB-251C Handheld Blower
Need oil/gas ratio for Echo back pack lblower - model PB-400E
Since every engine is different the manufacturer almost always has it printed in the gas cap. It should look like 50:1 or 50/1 (50 parts gas to 1 part oil).
Mar 31, 2010 | ECHO, Inc. PB-251C Handheld Blower
Pb1000fuel to oil mix ratio for echo
Fuel/Oil Mixture
Lou
Nov 09, 2009 | Echo Garden
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo Gas Blower 162 MPH 450 CFM Blower PB500T Logo
24 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
