Question about Exercise & Fitness
Repco RK 9900 model treadmill. Soon as you start up the treadmill a sing E7 appears and the treadmill shuts down. What is the problem and how do I fix this?
  • 218 Answers
SOURCE: We have an edurance treadmill model TX-6600 when
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
SOURCE: Repco Sports Treadmill
Repco RP300TM wont start E1 error message
Posted on Jul 14, 2011
SOURCE: repco fitness Treadmill error E7
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
Posted on Nov 24, 2011
  • 44 Answers
SOURCE: treadmill won't run the screen is showing E7
You probably need a technician to look at it. I would say the motor that runs the treadmill is faulty due to a fuse that has blown you would have to locate where this is first replace it and proceed to the nxt step. I say you may need a technician cos often you are dealing with mains power or small dc voltage in any case one should carry this out in a safe way.If you are not confident ring a professional Tech.
Posted on Dec 13, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 28, 2012
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
Repco fitness Treadmill error E7
Mar 26, 2011 | Exercise & Fitness
Can walk on treadmill but soon as i start to run it stops
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current limiting curcuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 20, 2010 | Reebok Vista Treadmill - RBTL13305
Jul 15, 2009 | Exercise & Fitness
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
