Question about Dishwashers
Miele f69. Used hook tool but still does not work f69 still comes up
I have a Miele 2670 dishwasher with an error code of F69---what is that and how do I fix?
F69 is a Plint float switch, usually placed in the bottom of the machine.
Oct 13, 2014 | Miele G2670SCSF Dishwasher
Hi This SBD 285-3 floorhead is for a miele s8310
Hi There,
I have to say i do warranty repairs for Miele and own VacuumSpot.com.au and I have actually never heard of this before either. The miele SBD285 is basically a good quality 35mm floor tool have you tried using a different type of tool. Wessell Werk (german manufacturer) make tools for Nilfisk, Electrolux etc make a range of tools and you may find that a different one will work perfectly for you. I am not sure where you ive but highly likely your local vacuum store will sell a version like this one which is truly excellent
http://www.vacuumspot.com.au/deluxe-german-35mm-combination-floor-head-ftw135-2
Sep 17, 2013 | Miele SBD 285-3 Classic Combination...
Fridgidare professional series range f69 error code
CodeF69 is going on my frisdgaire 30"stove How do I shut the beeping off
Jul 18, 2012 | Kitchen Ranges
How do I change a Miele heater pressure swith
first, make sure you need one. if you start a cycle, and the machine drains for 30 seconds, starts to fill, and then faults out on intake drain fault, you dont need a hps, your circulation pump is stuck. miele will send you a "hook tool" used for freeing the pump.
if your situation is not as I have described above, and your machine is faulting out later in the cycle, or will not heat, this is how you change the hps.
uninstall the dishwasher. **** up all the water from the sump under the triple filter. lay the machine on its side. remove the 4 phillips head screws that hold the bottom pan on. the hps is mounted to the circ pump at the back of the machine. push the locking tab in, and twist the hps a quarter turn. transfer the wires one by one to make sure they go back in the proper order. reinstall the switch. reinstall the bottom pan.
Jun 13, 2012 | Miele G848I Dishwasher
The inlet drain light and rinse aid light have both come on and the dishwasher is humming but not working. Any suggestions?
Hello Mark,
You didnt say so but i think it is a Miele dishwasher,its the only brand i know of with a Intake drain light
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced, if you contact via their website,they may send you that tool. To use it remove lower rack and pump filter and insert into the side of the pump hole(you will be able to see that hole with the filter removed) and rotate it back and forth at first it will resist then should quickly break free,if it is had to turn the pump/motor seal kit would need to be replaced.
Gene
Aug 07, 2011 | Dishwashers
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. After we...
If its been sitting a while, like 2 months or more, the circulation pump is locked up, need to call Miele, and they will send you a special tool to unbind the motor, its called a hook tool, they will send it to you free... works on the same principal as a garbage disposal tool....
Oct 09, 2010 | Miele 24 in. G656SCi Plus SS Built-in...
Circulation pump is stuck
Hello Stonegroup,
The impeller is located below the bottom filter trap. Remove the tray and at the twelve 'O' Clock position you will see a small opening. Inside there are the pump impellers. take the Hackenschlussel (Hook spanner/Miele tool) and insert it in the opening and turn. You should turn it a few times and be able to feel the impellers free up. Also, Make sure you run the dishwasher atleast once a monch to avoid the circulation pump getting stuck like this
Sep 17, 2009 | Miele 23 in. Novotronic G841 Built-In...
Hi The catch on my miele revolution has come off
Not sure about this, but have had a look at my own Miele which is similar. I suspect that, although it may not be visible, something must have broken to allow that catch to come off. Sorry, but you probably need a professional repairer to actually take a look at it.
Jul 17, 2009 | Miele S548 Bagged Canister Vacuum
Hi Sally If you download the manual this will be easier to explain:
http://www.miele.co.uk/Resources/OperatingInstructions/S%20556%20S%20558%20S%20658.pdf
If you look at page 22 you'll see the optional blower attachment and how to install it - ignore this - however it gives you the view of the two hinges on the actual accessory door. These clip on at either side of the front but there should also be a square partition on the back of the accessory door. Here is where the clip sits into the door and the parts hook onto two spring holders at the bottom. Once that is fitted the door should then go onto the front.
Jul 17, 2009 | Vacuums
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
