Question about Plumbing
Septic tank pump is brand new. Our alarm just went off and we looked in tank and the water is very high.... could it be a faulty pump?
    Sergeant:
    Habit-Forming:
  • 138 Answers
There could be a clog in your septic tank output line and your pump is not working. You can call a local contractor to find whats wrong and fix it quickly. Otherwise it can cause drainage backup and other septic tank issue.
If you need any septic tank parts, you can order it online.
Home page TG Wastewater
Posted on Apr 08, 2016
  • 739 Answers
Could be. could also be a clogged output line, a blockage in the septic field, even a sock stuck in the intake of the pump.
Posted on Dec 20, 2014
My high water alarm is going off.The septic tank is at normal level
Check the float switch, bad pump, bad switch, broken or frozen pressure line, electrical problem, plugged fields
Nov 12, 2017 | Plumbing
The light is on on my ryobi septic tank
two reasons light is on pump failure --no power or pump seized and the level in pump tank is high
Jul 27, 2016 | Plumbing
Do septic tanks need to be emptied? If so how often should they be emptied?
If everything is going as it should and the sludge in your septic tank is decomposing properly you shouldn't need to empty the tank too often, but its a good idea to periodically pump out the tank to ensure against problems. You should be getting your tanked checked once a year at a minimum.
Dec 26, 2013 | Plumbing
Septic effluent pump loses prime
DONT TRY TO EMPTY THE TANK, RAISE THE FLOAT LEVEL. THIS STOPS THE PUMP FROM SUCKING AIR WITCH CAUSES THE PUMP TO LOSE PRIME,
WOW THAT WAS A EASY ONE. ....NEXT
OH AND YOU MIGHT NEED A CHECK VALVE ??
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA
Sep 11, 2012 | Monarch Pumps BE-S75 Wastewater Pump...
Question i have a septic tank according to the drawing of the land. How can i find out if it has a sump pump. i am currently in the process of purchasing this home and there is a switch located on the...
that breaker could be the supply to the float inside the tank that sounds the alarm when full, check with the escrow company handling your purchase for full disclosure of the pump and installation, they should have all that if the pump and tank were installed with the correct permits . if they don't, ask for that Info from the seller ,
Aug 03, 2011 | Plumbing
Water level sometime very low, sometimes very high (almost overflow) and eventually returns to normal level. time can vary from 30 minute to 12 hours. at end of flush often a big explosive air bubble....
I would say the first thing you should do is, drain out your toilet using a cup and sponge, remove the toilet from the floor and inspect the base of the toilet for blockage. Also check the floor floor and gasket to be sure there are no restrictions. If all is clear then run a garden hose full pressure into the drain and see if it backs up. If the drain is blocked and you don't have access to a drain snake then you an go to a local hardware store and buy what is called a drain king that connects to the garden hose and pressurizes the drain to clear the blockage. If you dig up the septic lid make sure you have it pumped at the same time.And as always don't forget to use your rid-ex every other month. Hope this helps.
Feb 18, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Plumbing Logo
1,072 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
