we have GE 8000 BTU Portable Air Conditioner Portable Unit and it wont drain water into the pan, or out the back, and blows hot air every 5 min. it also will not pull humidity from air. it just blows cool, then hot, cool , hot, etc.....
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
How do i take my air conditioner off of override, it says to hold up/down to clear it but that...
(More)
How do i take my air conditioner off of override, it says to hold up/down to clear it but that obviously doesnt seem to be working.
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the...
(More)
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these units and this one just started to act this way end of last winter. Do you think it could be the varistor or something else on the control board. Thank You
fujita split system n13174 (2.5 and 1.5hp) does anyone have an installation instruction manual? i...
(More)
FUJITA Split system N13174 (2.5 and 1.5hp) Does anyone have an Installation Instruction manual? I found where the schema diagrams are and the Instructions - but no instal manual to be found. They are made in China. Could not find a website with product descriptions either. The installation instructions have been removed from the packaging. Allan from Melbourne, Australia
our panasonic air con model 06-855850 in one section of the pub keeps switching off/to idol every 10...
(More)
our panasonic air con model 06-855850 in one section of the pub keeps switching off/to idol every 10 minutes and just blows air not cold air out yet the other ones stay on in the other section and is the same make and model and is constantly on
my ac unit instead of draining from the back drain tube when in the down position, it still drains...
(More)
my ac unit instead of draining from the back drain tube when in the down position, it still drains into the drain tank or bottom right of unit
