Question about GE Washing Machines
My wcsr4170g2ww ge washer is giving bad motor blinking light, what gives on this board, someone must be fixing these thing and not buying a complete new motor. Rest unit still no spin no adgatate
SolutionGuy
  • 331 Answers
SOURCE: GE Harmony Washer, Model: WpGT9360pl
John, there is debris of some sort inside your drain pump restricting or impeding the flow of water. Since it still has water in the tub, the computer won't allow the unit to activate high speed spin. The blockage will have to removed before the unit can be operated again. You'll have to pull the back cover off the machine to access the pump. When you remove the hoses, there will be a flood of water... If at all possible, move the washer outside to do this. If you can't move it, figure out a way to clamp off (pinch) the intake hose tightly. I've used 2 small open end wrenches and a pair of vice-grips before. Take the 2 wrenches and pinch the hose, then secure them tightly in place with the vice-grips. This'll get it going again. BTW, your washer has no belts... all electronic drive.
Posted on Jul 29, 2007
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
  • 212 Answers
SOURCE: Code F43 on frigidaire front load washer.
motor control possibly bad
Posted on Jun 20, 2009
SOURCE: GE WBSR3140GWW top load washer
I had the same problem and solved it without all the expensive recommended parts. I unplugged the cord from the outlet and listened for a "click" (motor reset) and then plugged it back in. I then raised and lowered the lid several times to break the magnet contact. turned it on and then it worked fine.
Posted on Jun 14, 2010
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
Mar 24, 2013 | GE Spacemaker Washer and Dryer Electric...
Will not spin or agitate
Remove the front panel. Observe the motor flashes.
The motor blinks on and off all the time.
It blinks faster when running.
If a failure occurs you will get the following flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lid switch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes. If no light is visible you have a blown fuse built into the neutral side of the harness on the white/red wire.
themobilian_2813.jpgthemobilian_31.pngIf you see a small bubble in this black heat seal and the motor light is not on then the fuse within is blown replacement part is WH49X10041
What else do I have? Oh yeah how about the SERVICE MANUAL
Aug 12, 2011 | GE Profile WPRE6100G Top Load Washer
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men (bad motor)
7 flashes bad lidswitch.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
Mar 16, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
My ge washer WJSR4160G1WW is only 4 years old and only 2 people live here and I do not wash but once a week usually, and it drains water ok but the clothes are wet does not seem to be spinning and I don't...
Try resetting the inverter and see if she will act right. Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
Jan 08, 2011 | GE WDSR2080D Top Load Washer
WPGT9360EPL is giving me the error message saying "a problem has been detected with this unit" then the machine turns off completely.........i wonder what board is it? is it the main board? or the control...
Probably neither. There are several things that could cause this error. Motor, water valve pressure switch and so on I have never had to replace a control board on this machine.
Feb 22, 2010 | GE WPGT9360EPL Top Load Washer
GE washer fills, empties, won't agitate or spin. model whdrr418giww only about 18 months old
you will have to remove the front panel of the washer. then look on top of the motor. on top of the motor is a control board. whille the machine is turned on, you should see a flashing light located in the middle of the control board to the right. you will have to count how many time that light blinks.
once you have a count, gain access into the control console(where the timer is) by removing a few screws. in there you will find a tech sheet that will tell you what the blink count means. i bet you its the motor thats bad. its about $160.00
if you need to order a part goto http://lartoday.com/order_parts.htm
good luck
Levi
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 10, 2009 | GE Washing Machines
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
GE Washer Motor over amp?
If that's the only thing wrong with it, then go to http://www.appliancepartsdepot.com
They are about the most reasonable priced place I have found.
Dec 24, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
