Question about Arris SURFboard® SB5101 Cable Modem
Wpa2 password for motorolo surfboard sb6141 - Arris SURFboard® SB5101 Cable Modem
Find network key on sb6141
The term "Network Key or Passphrase" indicates your printer is asking for a WiFi password, but the SB6141 is not a WiFi capable device at all, it's just a Cable-to-Ethernet device. So then, you need to look at your WiFi router, which should be connected with an Ethernet cable to your SB6141. If this doesn't match your setup, you'll either need to get a WiFi router hooked up (that process will contain the answer to your question) or simply use an Ethernet cable for your printer.
Nov 09, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
How to reset password for motorola surfboard cable modem sb6141
There is no password on the SB6141.
There are no user configurable options. Any configuration is changed through communication with the CMTS.
When you access the modem (192.168.100.1) all you can do is monitor the signal quality and certain log entries.
NOTE: the "configuration" page allows you to reset the factory defaults and to restart the modem. IF you reset factory defaults this note applies:
Resetting the cable modem to its factory default configuration will remove all stored parameters learned by the cable modem during prior initializations. The process to get back online from a factory default condition could take from 5 to 30 minutes. Please reference the cable modem User Guide for details on the power up sequence.
Aug 24, 2014 | Motorola Computers & Internet
Sb6141 manual download?
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CBwQFjAA&url=https%3A%2F%2Fwww.myaccount.charter.com%2Fcustomers%2FGETBINARY.xbin%3FID%3D3285&ei=HpjoU63dMY7-oQSYn4HYBQ&usg=AFQjCNH1cDo1DclS2cS5GlYLP3VetIBM3A&sig2=frmdRQ9j96xqhleEHd1B9g&bvm=bv.72676100,d.cGU&cad=rja
Aug 07, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Comcast cable says they don't update firmware. l have a SB6141 motorola DOCSIS 3.00 and l just upgraded to 105 mbps. l'm hardwired to my modem. l'm only getting 32 power level ?
You may need to enable IPV6. All Comcast modem updates are done automatically. I would contact ARRIS for additional assistance. Comcast also has a helpful online community.
Mark
Motorola Mobility Support
Jun 18, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Need to open ports on my surfboard sb6141 to play on playstation3
surfboards are not routers... you need a router connected to your surfboard on the WAN port of your router. Then, port forward the ports you need to your play station.
Feb 28, 2014 | Computers & Internet
I need to find the WPA2 key. Can you tell how
TRY CALLING THE COMANY OF THE MODEM OR YOUR SERVICE PROVIDER
Feb 01, 2014 | Arris SURFboard SB6141
Surfboard 6141 default password
user: admin
password: password
If you have a retail one it probably won't work.
Instead go to http://192.168.100.1/index.htm
Jul 27, 2012 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Arris SURFboard® SB5101 Cable Modem Logo
74 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
