Question about Health & Beauty
Have Phoenix scooter s35015 4 wheel . Batteries charged turn on and pull throttle red light sysrts flashing nothing happens.
5 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
Posted on Jul 25, 2009
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
  • 692 Answers
SOURCE: DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
Posted on Oct 27, 2010
Testimonial: "Thank you for taking the time to answer my question."
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
Oct 24, 2015 | Electric Wheels Ew36 Mobility Scooter Red
How to fix scooter when red light flashes 5 times
hi, i need you tell me what controller type is fitted to that scooter before i can be more precise with fault info ,, the controller is a black, or blue or silver box located under the rear cover of the scooter ,, the wires lead to this unit...
Regards
Rob
www.gewizrepairs.co.uk
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Phoenix 3 battery charge idicator
Hi, is it possible for a picture of this ??? the reason being they used two diif versions so I want to be sure...
By the way you say you changed the batteries but what about the charger, are you 100% sure that working okay as in charging the batteries to a ideal voltage level around 27.5 DC ,max voltage should no more than 28.2 volts DC, this will give you a 100% usage of the batteries in question...
Regards
Rob
Feb 01, 2014 | Drive Medical Phoenix 3 Wheel Compact...
Raggta 6 scooter not been used for 12 month,red light on charger flashing all time
A flashing red light orLED on most mobility scooter chargers means the Batteries have a defect as mostchargers also test the condition of the batteries. This has happen becausemobility scooters batteries loose charge when not in use, and need a maintenancecharge at least once a month (best once a week). If this is not done batterieswill fail! Get the batteries load tested to confirm that they are faulty,
Oct 26, 2011 | Health & Beauty
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Hope this helps
Oct 27, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Just bought my dad a second hand go go 3 wheel elite scooter
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
Schwinn S180 won't charge
NashvilleDan, this scooter has 2 12v 10 amp batteries in series, you should read over 24 volts at the charging hub if the batteries are good. I would think that if the scooter sat for over a year you have bad batteries, They can be purchased at battery plus.
Mar 19, 2008 | Transport Schwinn Rechargeable Portable ...
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
