Question about Garden
How to check gear box oil on snapper ir4000 tiller
3 Suggested Answers
  • 8404 Answers
SOURCE: I have a horse tiller. How do you ck. the oil in
Hole in the top side casting ... remove the plug. 90 or 110 weight gear oil available at yor auto parts store or other fine retailer who sells lubricants.
Posted on Jun 24, 2010
dogsled48195
  • 411 Answers
SOURCE: how to check gear oil on a mtd mimi tiller how
I would say 90 weight gear lube go to a boat supply get a tube of 90 weight I dont have your model # so check on your owners manual
Posted on Mar 20, 2011
What type of oil goes in the crank case in a Scotts model 6070S, rear tine tiller?
normal engine oil in the engine sump
gear oil 80 oep in the gear box
Jul 21, 2016 | Garden
What oil do I use in the Botton Gear Box
90 weight gear oil GS-90 same as motor cycle is what I use.
Jan 03, 2016 | Garden
I have a 900 series poulan 6"5 HP tiller what type of gearbox oil what weight
The safest to use is oo grease. Snapper used it on all chain and gear assemblies. It's expensive, save yourself the trouble. Go to tractor supply and get something called "Super S Cotton Picker Spindle Grease 00" . It's $5, better staying power than 90w oil and comes in a bottle you can squirt into the fill hole.
Aug 24, 2015 | Garden
What lubricant is used to lubricate the gear box on the gc720r roybi tiller attachment
hello, i use go 80 rear end oil,works good,hope this helps.
Feb 14, 2012 | Ryobi Garden
Jerry, I just want to service the gear box on my front end tiller, I guess just opening it and adding grease. Anything else that I need to do to this 40 + year old tiller?
Is the gear box still good? In a lot of older tillers the gear boxes go bad. This is normally due to weeds getting wrapped around the tines and rubbing away at the seals in the end of the gear box. If you have to add oil (grease) then the seals are probably leaking. You should not have to open the gear box up, there should be a plug in it. The plug should be about half way between the bottom and top of the gear box. You should be able to fill the gear box up to that plug with a squeeze bottle. Please rate my answer so I am rewarded points for it.
Jan 29, 2012 | Mtd Garden
What weight oil goes into the gear box? whats the proper weight oil for the motor?
30 weigh oiltdetergent (if available,if not regular 30 weight oil will perform also), as for the gearbox.transaxle for the tines use 80-90 weight gear lube
Apr 16, 2011 | Troy-Bilt Pony Garden Tiller
How much gear oil for gear box and gear case
most gear boxes have a bottom drain and a side fill plug , you fill until the oil runs
out of the top plug
Oct 18, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
I have a horse tiller. How do you ck. the oil in the gear box. Whate wt. of gear oil do you use.
Jun 23, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Tiller engine runs but the tines will not turn
You should look at gear box oil and see if there is metal in the oil.If there is you will need to check the gears for excess wear.Also make sure rpms are in the operating range.Let me know what you find.
Mar 22, 2009 | Mantis 2-Cycle Tiller
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
