Question about ASUS P5KPL-AM/PS Motherboard
No bios, No beeps, blank screen how to repair
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
Http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%2fPS&p=1&s=22
ASUS SUPPORT.AFTER WHAT I UNDERSTAND YOU GOT NO BIOS OR DRIVERS.
Posted on Jul 31, 2013
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
When I power on screen shows Compaq boot screen then flashes to black then back to boot up screen. I cannot go any further. Please help.
Regarding with problem basically some part their failed. You need to check the RAM and HDD. Reset the CMOS battery remove the CMOS jamper with in 5 seconds and put it back. If you loss the first try you also recovery, to recover load the windows CD and boot up repair the windows until it is done. Good luck!
Regards
nicole
Oct 03, 2009 | Compaq Presario R3000 Notebook
I think I updated BIOS from Dell incorectly. Downloaded to "C" drive,replaced old BIOS with update. Resart. Blank screen, six beeps ( four then two), power light green,hard drive spins fast & blank...
Sounds like the BIOS upgrade didn't take. Those beep codes are audible indicators that the motherboard has failed POST (Power On Self Test).
Here's is a list of the codes for your specific BIOS/PC:
http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm#wp1052968
Sep 04, 2009 | Dell Dimension 4700 PC Desktop
Dead T4220 - 4 beeps @ POST & blinking lock symbol, screen blank
this beeps are signal of a dead cpu or memory. Check with manufacturer to confirm diagnostics.
Jul 08, 2009 | Fujitsu LifeBook T4220 (A1A5J1A414B30000)...
Blank screen when on with 1 long beep and 3 short beep
Start your pc when you get to the screen that shows in the top right corner F2 & F12 at this time press F8. At this point you can either scroll down to and click on " Last Good Configuration" this should the problem.
Good Luck =)
May 20, 2009 | Compaq Presario V2401CL Notebook
My desk top pc is steady beeping
if on power on u see nothing and just hear beeps and see blank screen with no text/signs of bios loading then my firend
ur RAM is faulty try replacing them and then tell me i can solve ur problem
hard disk comes after RAM if ur RAM is faulty ur system will never boot up and will give u beeps just disconnect the hard drive cable and check it ur selves if it boots to bios
pls ask for more help u want
regards
pls do rate me fix ya if i fixed ur problem
Mar 02, 2009 | E-Machines T2042 PC Desktop
Blank screen
This could be due to many issues. The most likely in my mind are:
1. A dead hard drive, but then at least the BIOS should come up
2. A shorted out or disconnected video connection (it connects at the hinge where the laptop screen folds down)
3. A plugged in USB device that the computer is trying to boot from
About #3, seriously, I've seen it happen. No BIOS, no Windows screen. Just a blank screen and a beep until you remove the USB device.
Dec 09, 2008 | HP Pavilion dv6000z Notebook
BLANK SCREEN-ACER ASPIRE 3661
You can check the little indicator light on the notebook.
If the hard drive was dead, that wouldn't cause the display to go blank.
If your problem was with your hard drive, you would still get the BIOS screen and then a message about being unable to load an operating system. So, I doubt if that is the problem.
My guess is that you have a relatively serious motherboard, video card, memory, or CPU problem.
When you turn it on, does it beep ? If so, how many times ? You can translate these beep codes at: http://networking.ringofsaturn.com/PC/beep.php __________________
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
ASUS P5KPL-AM/PS Motherboard Logo
114 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
