Question about Canon CanoScan N640P Flatbed Scanner
Printing - using the 'copy' mode of the scanner
I can scan documents/pictures ok but I want to copy something. The printer should start printing as soon as the scan is finished but it's not working:( although the printer is working for all other jobs. Using Windows Vista home ....Cannon S200SP printer. Thanks for any help.
    Genius:
  • 2,985 Answers
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Posted on Sep 01, 2007
6ya staff
SOURCE:
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
CANON PIXMA MP810 PROBLEMS - Aghhhhh!! I can
Try this,
scan the document to the computer, then view it using a picture viewer.
You may see that the scan is faulty!
The printer may be printing exactly what it sees!
Mar 07, 2010 | Canon PIXMA MP810 All-In-One InkJet...
How do I make copies
What do you mean by copies? Like printing 1 page in more than 1 copy?
In the Print dialog box (when you click the File => Print command), You can increase the number of copies to be printed in just one printing.
If your printer is multi-function (one printer that can scan, copy, and print), just place the document to be copied (photocopy) in the scanner tray, cover it and then PRESS the OK. In some models, it is MONO or COLOR under START button group.
Feb 06, 2010 | Office Equipment & Supplies
Not printing from Smart Panel option
Because they can't talk directly to each other. Kind of like the scanner is speaking in German and the printer is Spanish....The application used for the scanner is bilingual, therefore the printer can understand what it is supposed to print.
Dec 22, 2009 | Epson Perfection 3170 Flatbed Scanner
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Canon CanoScan N640P Flatbed Scanner Logo
117 people viewed this question
Clive
Clive
old marine
old marine
Ekse
