Question about John Deere Starter Tractor Lx188 Kawasaki Engine
Lx188 stalls when blades engaged - John Deere Starter Tractor Lx188 Kawasaki Engine
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Why wont blades stay engaged ?
Check the drive pin in the tractor belt drive pulley. If the pin is broken it will have enough pull to turn the blades slow but will slip when the gas is applied. To repair you will need to remove the drive belt and take the pulley off the drive shaft and get a new pin and reinstal.
Jul 24, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
I have john deere lx188 rideon mower when i engage the pto the engine cuts out.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Dec 09, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do you remove mower blades on john deere lx188
Get yourself a rattle gun connect it to an air compressor with the right
size socket hold the gun on reverse it should remove the bolts.
Apr 22, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
John Deere Starter Tractor Lx188 Kawasaki Engine Logo
29 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
