Projector was working and then suddenly stopped-- Sawyer slide projector 747AQ
  • 6 Answers
SOURCE: I can't get the light to come on.
Sounds like your black screen shutter is not opening allowing light to pass through. Try it with the carousel and slides installed. Run a few passes.
Posted on Dec 08, 2007
  • 33 Answers
SOURCE: why wont it stop
With that style (4400) of projector, this was usually caused by the trigger on the clutch assembly getting gunked up with dirt and/or grease. Assuming you've removed the bottom of the projector and it's now upside down, lens facing away from you, you'll see a large white gear and near the edge of it will be a grey metal sort of trigger. On it may be resting the L-shaped finger attached to a solenoid.
IF you are confident you can operate this safely with power applied, you can do this, ONLY to help pinpoint the location if you need help. Then remove the power again. *If you are not sure, do not apply power.* Using the remote control so you do not have to put your finger near the cycle (forward/reverse) buttons on the projector's side, activate the forward button, with power turned to fan only (or remove the lamp module). You will see the L-shaped solenoid finger jump briefly and the grey metal trigger
may rock a bit as the gear turns around. And in your case, continues.
Disconnect power if you had it on, and look at the little grey trigger. There is a tiny spring on it and it pivots when you press gently on it. What should be happening is that the L-shaped finger gets caught on that grey trigger and stops the rotation of the gear, as the trigger rests in the edges of the gear. When the solenoid is activated, the L-shaped finger jumps up, releasing the grey trigger which can then rotate one cycle. The trigger should immediately have gone back to its resting position so that it catches the L-shaped finger again and the finger holds the trigger which holds the gear(clutch) from rotating.
Dirt and lubricant has gotten in there and the grey trigger cannot return to its position in time. Eventually it may if you let it cycle long enough. The solution? Use some contact cleaner to clean out the gunk from the pivot of the trigger. It shouldn't take too much. In a pinch you can likely use isopropyl (rubbing) alcohol with cotton swabs. Clean away all the gunk you can but be careful not to get the degreaser on other components. Lint free cloth or paper towels around the clutch gear may be helpful.
Now, the trigger should be able to return to its resting position quickly. If not, repeat degreasing- again it usually doesn't take much. Now, put only one (maximum 2 small) drop of very light oil. Consumers can use sewing machine oil. Too much will later lead to the problem recurring.
Now your projector should be cycling fine, though you might have to turn it right side up to judge accurately. If so, turn it over again,power off again and look where the grey trigger and the L-shaped finger contact each other. Steal just a little bit of grease from the large white clutch gear -use some soft plastic piece like a cotton swab shaft so you don't gouge the gear- and apply it to the contact point. This is not absolutely critical but is recommended to avoid excess wear at that point.
Reassemble, being careful to dress (put inside the housing) the wires so they don't get pinched. Do not over tighten the body screws. If you like you can e-mail me at bytebackkw@yahoo.ca and put "Projector" in the subject line.
Posted on Mar 28, 2008
  • 412 Answers
SOURCE: I cannot get my projector to stop rotating the
This problem is caused by the cycle contact requiring an adjustment. Unplug the projector, remove the lamp module, turn the projector upside down & remove the bottom cover. Near the center of the projector is the Slide Change Mechanism. At the center of the mechanism is the Camstack. Refer to the illustration for the correct position of the clutch contact to the cycle pad. You will have to bend the clutch contact wire (GENTLY) a little bit, then plug in the projector & cycle it Forward a few times and check the position of the wire to the pad. This adjustment usually takes a trained hand a few times to get the position correct. If you don't want to tackle it, contact a factory-trained repair dealer for assistance. Good Luck !!jauburn_4.jpg
Posted on Dec 21, 2010
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: will not change slides forward/backward, remote focus ok,
Your problem is most likely caused by a broken wire under the control panel or a wire somewhere in the "cycle circuit" that is no longer connected. You should seek out a factory-trained repair dealer who has a schematic that can trace down your projector problem.
Posted on Jan 04, 2011
Sawyer slide projector blew house fuse when plugged in. Now fan works but no lamp. Tried changing bulb but still doesn't work. Anything else I can check?
Sounds like a short (internal fuse maybe) to me. If you can confirm that the lamp is intact and should function, then it has to be something between the lamp and the power source. Assuming everything else works properly.
Nov 05, 2017 | Office Equipment & Supplies
Kodak 650 slide projector that won't advance the slides with remote
Don, Does the projector still cycle from the side (on-board projector) buttons?? If it does, then you have a bad remote (parts are still available from: www.micro-tools.com). If it will not cycle from either the remote or the side buttons, then chances are that you have a broken solenoid link. If you are not familar with the projector & proper disassembly, I'd contact a dealer. Again, you can still get the necessary parts from micro-tools. Good Luck !!
Jim
Apr 02, 2012 | Kodak Office Equipment & Supplies
Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
Dec 15, 2011 | Kodak Office Equipment & Supplies
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
The fan has stopped working, and the projector has shut down and will not turn on. The bulb is still OK.
The thermal fuse behind the lamp module has opened (usually due to a high internal temperature). On some occasions, this is caused by a fan belt failure. Because this involves primary voltage, I would recommend you take the projector to an authorized repair dealer.
Nov 09, 2010 | Kodak Carousel 4400 Slide Projector
My projector suddenly stopped working
The instruction manual says that to reset the timer you have to hold down (simultaneously) the Menu button, then Enter button and the Down arrow...then press the Standby/On button on the projector. This worked the first time I replaced the bulb, but now that I've had to replace it again, its not working. Good Luck.
Mar 21, 2009 | Sharp DT-100 Multimedia Projector
Will not change slides forward/backward, remote focus ok,
Mar 15, 2009 | Kodak 4200 Slide Projector
Mar 05, 2007 | Vivitar V5000AF Slide Projector
Slide projector autofocus constantly adjusting
My slide has the remote but remote is not working the projector i have is v5000Af
Jan 02, 2007 | Vivitar V5000AF Slide Projector
k24674
jasbo
jasbo
