Question about Starbucks Electric Milk Frother
Won't start frothing - Starbucks Electric Milk Frother
Nespresso milk frother instructions
I had the same problem. From reading various sites it is clearly a common problem. Most suggest phoning Nespresso to get it replaced but one website suggested turning the machine upside down. Not the base, just the aeroccino. Leave it like this overnight and it resets itself. I don't understand how that works but I tried it as it was a weekend and wasn't going to be able to call the helpline till Monday. And it worked! I now have proper froth again. Other suggestions seem to be try never to get the underneath wet (I think leaving it upside down ensures this area dries out completely), don't leave it on the base when not using and certainly don't leave it on.
May 19, 2013 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
My nespresso machine won't froth the milk
Brand of milk definitely matters... Here in Canada I used Sealtest 1% when I first used it and the froth was thick light and luxurious. Then one week picked up Neilsen 1% and found it produced absolutely ZERO froth. Back to Sealtest...back to froth. Milk brand matters....but don't know why.
Jan 14, 2012 | Nespresso Aeroccino Automatic Milk Frother
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
Feb 15, 2011 | Nespresso Aeroccino Automatic Milk Frother
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Too much froth
Does this happen after you make several froths or the first time you start the machine? Try removing the panarello and froth milk that way then see if this is happening too without the panarello. I found that panarellos are great as a "quick learning to froth?- but they do have the tendency to froth milk too much without heating it up ( to the temperature that you like).
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Starbucks Electric Milk Frother Logo
139 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
