Question about Craftsman Garden
Craftsman riding mower model # 917.287301 will not move. Starts but push pedal and it goes nowhere.
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
wadembly
  • 513 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
Hi Jerry:
My Craftsman ride on Mower does not have "gears" as such.
There are separate forward and reverse pedals.
Can you give us a model number for your machine?
Jul 07, 2015 | Craftsman Garden
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Why won't my riding mower start, using the key?
There should be a switch on the gear shifter so it will only start when in neutral. If the switch is bad (or the shifter is in gear) the solenoid with not engage.
May 05, 2014 | Craftsman Garden
Riding mower won't go nowhere it's got drive belt on but won't drive
Is it a hydro? check the release lever some times i forget too. If its gears then try different gear and check that the belt is engaging fully if the clutch spring broke your pedal shouldn't push back up.
Oct 03, 2012 | Craftsman Garden
My craftsman re2000 starts but wont move...seems like it is stuck int neutral
check the belt tension then check . then check the rod on the rear of the mower to see if the rod you pull when you want to push it is not released
Apr 18, 2012 | Craftsman Garden
Mower starts and runs, blades turn but will not move, what could be the problem?
the blades and the trans use 2 different belts also is it a automatic drive and the release lever that you pull out to push it?
Apr 05, 2012 | Craftsman Garden
Lawnmower wont move in fwd or reverse
Is the brake sticking. On my craftsman mower there is a bar under the brake pedal that pushes back a lever when starting. And the lever sticks. I have to reach underneath and pull the lever forward and then the mower goes. I haven't found a solution to that yet.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman hydrostatic strains but won't go forward or reverse
There is a brake lever attached to your transaxle, that when activated, pushes dowel pins which serve as brake pistons, against a brake pad which presses against a disk from your transaxle...whew. Much like a disk break on your car.
The pistons, or dowel pins may be sticking, causing you to be "riding your brake". A little disassembly and some good ole WD-40 might loosen up the bind.
Aug 25, 2009 | Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
