Question about Toshiba Satellite M30X Notebook
Battery led flash on charge
I have a problem with the notebook, when i put im on charge the led dont stay on, he stays flashing.
  • 78 Answers
Hi, Flashing LED indicates a short circuit. Try removing battery and reinserting it. Also if you can try removing the CD/DVD drive and see if it works with this out. Then the same with the Hard-Drive. Let me know how it goes
Posted on Aug 31, 2007
SOURCE:
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
Power socket sony vaio
Look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 04, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Nov 14, 2009 | Acer Aspire One PC Notebook
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
[email protected]
Oct 28, 2009 | HTC P3300 Smartphone
The socket pin is defective, i have to wiggle it just to get it charged, however, im having a hard time to charge it. where do i go to have the socket pin replaced
Connect the power adapter to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first from a computer repair shop in your area.
Oct 26, 2009 | Acer Extensa 4620 Notebook
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Acer notebook not working
change ur battery n c.. i think ur battery is dead.. nt sure
Feb 14, 2008 | Computers & Internet
Toshiba Satellite M30X Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
