Question about London Fog Oxford II Luggage Collection
Open locked London fog suicase - London Fog Oxford II Luggage Collection
I have a mitsubishi galant 2007.The door power lock will not open or lock with the remote.In other words it unlocks and lock with the car on.Also the dome light have stop working.
power locks circuit hot all the time with ignition on or off.sound like remote battery need replacing also check fog lamps fuse or relay either one bad will cause no fog lamp operation.
Feb 28, 2013 | Cars & Trucks
What is a limited edition london fog coat with fur on inside worth
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Sep 18, 2012 | Cars & Trucks
How can i trace a short in my 1998 mercedes e320
check remote batteries for replacement. they may be dead as for the door locks and trunk. as for the fog light, parking brakes situation a short would make them not work. not stay on. the electrical would be fused for that. a short prevents electric from getting to the load or device. i would not think that fog lights would be linked to parking brakes. did you mean parking brake light? the fog lights should be on a switch by themselves or connected to main headlamps
Mar 25, 2012 | 1998 Mercedes-Benz E-Class
How do you replace the fog light bulb on 2008 avalanche
    • 1 Open the hood and reach down into the engine bay for the fog light assembly. If you cannot reach the fog light assembly from the top you may need to get underneath the truck to reach it. Remove the electrical plug running to the fog light ballast.
    • 2 Remove the bulb. Unlock the fog light bulb by turning it counterclockwise and pulling it straight out of the assembly.
    • 3 Slide a new bulb into the fog light assembly. The part number you will need for the new bulb will be located on the ballast or base of the old bulb.
    • 4 Turn the bulb clockwise to lock it into the fog light housing.
    • 5 Reconnect the electrical connector to the bulb ballast.
Jan 23, 2011 | 2007 Chevrolet Avalanche LTZ
How to change Ford Explorer fog light
p, li { white-space: pre-wrap; }
Open the hood and remove the electrical plug from the back of the fog light ballast below the headlight assembly.
Turn the fog lamp counterclockwise to unlock it from the fog light housing.
Insert the new fog lamp. Align the notches on the fog lamp housing with the tabs on the new bulb and turn the bulb clockwise to lock it into the housing.
Reconnect the fog lamp electrical plug.
Sep 13, 2010 | 1999 Ford Explorer
Tenho 1 fogão DCS-RG364GD à
i cant help but here it is translated to english.
I have 1 fogã£o DCS-RG364GD the 10 years and am needing 2 springs of the door of the Ref oven: 211344-30" Door Hinge Nuova Star and 2 lame person - Ref: 211346-Receptacle Nuova Star another one peã§a: 210828-Spark Module - amount 1 My son this ¡ in London, as faã§o to buy these peã§as wool ¡ I wait an Obliged return Isabel dabelgastronomia@ uol.com.br
Feb 23, 2010 | Kitchen Ranges
Hi, how do i open the fog light and replace the light bulbs? on a 1998 forester.
Remove the 2 screws in the lens from the fog light and remove it.
then you can remove the lamp (Its a bajonet lock)
Oct 11, 2009 | 1998 Subaru Forester
2001PT Cruiser door locks
The fuse is No.3 "DR locks" (near steering wheel)
If you take the fuse out the doors will not open itselves.
The root cause of the problem will be a microswitch inside the drivers door?
Check this:
http://www.ptdoityourself.net/tl/tl_index2.html#8n
======FOG LIGHTS ============
1.At first take out the foglight's fuse before you battery is dead. (Fog lights stays "ON" even you leave the car).
2.You must replace the Multifunction control switch =(
Here is the photo of problem:
http://www.ptcruiser.fi/ptgalleria/albums/userpics/10010/normal_sumuvalokytkin.jpg
Fog lights are connected to pin 13,14.
Fog light switch is "B". Because the current is many Amps, contact surfaces are heating up.
After that the contact opening "C" is melting (made of plastic) so the fog light stays "ON".
May 20, 2009 | 2002 Chrysler PT Cruiser
London Fog Oxford II Luggage Collection Logo
123 people viewed this question
Top London Fog Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a London Fog Luggage and Travel Expert? Answer questions, earn points and help others
