Question about Panasonic SC-HT75 System
Trying to connect Surround sound system with 3 Other Components!?
Need to know how to connect the Sound System with 3 other components, which are: A DirectTV Receiver/Model #D12-300, Panasonic VCR/Model #PV-V4525S, and A Sony TV/Model #KV-24FV300. Have followed the Panasonic Surround Sound booklet which ONLY gives connection directions to the t.v. which is completed - How do I do the rest?!
  • 1 more comment
  • sdrums Aug 31, 2007
    Solution #1posted on Aug 31, 2007
    By sreekidu
    Rank: Guru
    Rating: 88.2%, 61 votes
    hi,
    you need to have 3 pair of audio-in ports for that.
    i think your sound system has 3 input ports.
    ie,
    1.tv in ->u can connect this to audio out of your tv
    2: vcr in ->u can connect this to audio out port of
    This is the solution I received. But If possible I would like to have a description or diagram (in sequence} of what goes where starting from the cable coming in from the satelite. Thank you
  • Anonymous Mar 25, 2014
    I am unsure as to where to connect the cables of the foxtel unit through the surround sound system
    How do I connect my foxtel unit through my surround sound system
    President:
  • 3,130 Answers
What you have to do is to connected the Direct TV receiver and the Panasonic VCR directly to the TV set. This way when you go to the input on the TV set that this equipment is hooked to, the sound then comes out of the TV set and goes into the surround system through the cable you have coming out of the TV set marked TV out to TV audio input to the surround sound. This surround sound only has a line output, a tape output, and an aux. input. You have only one input to this surround sound unit. You should have at least two separate video and audio inputs on the TV set to use for your other equipment, and to use the other equipment through the surround sound, you simply leave the setting on the surround sound on the TV mode and and switch the different inputs on the TV set. Good Luck
Posted on Aug 31, 2007
    Sniper:
  • 60 Answers
Hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
SOURCE:
Timer mode is locked on vcr
You must have set a timer record. Press the button that sets a timer recording and cancel them. If you have the manual check what it says if you don't have a manual Panasonic do have PDF of most videos free. IF you can't clear try the factory reset opition.
Jan 14, 2013 | Panasonic 4-Head VCR PV-V4525S
Need code for panasonic vcr pv v4525s
Hello
Setup codes for Panasonic VCR with URC4220 universal remote control are:
0035, 0162, 0616, 1062
OK.
Feb 22, 2011 | One For All URC4220 Remote Control
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
I have a panasonic vcr. Model # pv-v4022
There is an SMPS unit that powers the set. You could have a failed driverr in this section. check out the input side for short in capacitors, bridge rectifier,SM driver or a mains protector. It will easy to identify by having a continuity tester for identifying the short. replace with the same type. good luck
Jun 30, 2010 | Panasonic PV-V4022 VHS VCR
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
I have a Sylvania TV that does not have a separate audio in/out connection. It only has 2 composite wire connections one on either side of the TV...I have a Sony DAV-BC150 5.1 surround system and a...
Maybe I don't quite get what you're trying to do.
Unless you still tune programs off the air from the TV tuner and an antenna - what possible TV program would come into the TV that the DirectTV box wouldn't already provide high quality sound and video for? You should run the audio from the DirectTV box to the receiver.
May 04, 2009 | Sony DAV-BC150 System
Can not locate vcr remote code for Panasonic model PV-V4525S
Go here www.remotes.com they will have that info listed for you!
please rate this response and keep this a Free service!
Jan 23, 2009 | Televison & Video
Problem with Panasonic PV-7661 VCR-blank screen for DVD function
Video loss could be caused by either the respective cable or output/input connection on related component...accordianman
Feb 11, 2008 | Panasonic PV-7661 VCR
Panasonic SC-HT75 System Logo
593 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
