Question about Sanei N86 Full Metal Cover 8inch Dual Core Android 4.1 Tablet PC RK306
I how a sanei n86 tablet I've forgotten the password, and the primary remove password pleas
Forgotten password for Aspen x1 dual boot 10" tablet pc
Get this password tool for free (giveaway will expire after 15 hours):
https://www.giveawayoftheday.com/password-recovery-bundle/
It allows you to create a bootable CD/USB that can help you remove forgotten Windows password.
Nov 28, 2016 | Tablets & eReaders
How do i reset my password on my linda pitts 06@ gmail account
When logging in press forgotten password option and follow instructions!
Dec 26, 2014 | Samsung Galaxy Tab Tablet PC
Sanei tablet not switching on
It's normal for a device to heat up during use and charging. As long as it's not too hot to hold, there isn't a problem. If it is hot enough to burn you I'd replace the battery
Dec 08, 2013 | Sanei N80 8GB Allwinner A10 Cortex-A8...
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
How do i do factory reset on sanei n91 tablet
How do i do factory reset on my daughters sanei n91 tablet she lost pattern lock and had tablet in flight mode so cant recover from email holding power and volume does nothing for reset.HELP
Mar 07, 2013 | Tablets & eReaders
Sanei n10 manual english
i have sanei n10 tablet and i lost the password and google accaunt what can i do ?
Jan 21, 2013 | Easy SANEI N10 Android 4.0 Tablet PC 10.1...
Sanei N86 Full Metal Cover 8inch Dual Core Android 4.1 Tablet PC RK306 Logo
23 people viewed this question
Top Sanei Tablets & eReaders Experts
Are you a Sanei Tablet and eReader Expert? Answer questions, earn points and help others
