Question about GE Microwave Ovens
Size of GE microwave oven model JVM139J002 - GE Microwave Ovens
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
bestdarngood
  • 3037 Answers
SOURCE: run but does not heats
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
Posted on Jun 07, 2009
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
What size screws does it take to attach it to the cabinet?
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 16, 2016 | GE Microwave Ovens
I need to replace my over the range GE microwave Model # JVM1330WW002 and don't know what size/capacity it is?
Get cubic foot size by multiplying height x width x depth.
Divide that by 1728. If oven is 12 x 12 x 12 then it's exactly 1 cubic ft.
If 6 x 6 x 6 then it's 1/2 cubic ft or. 50 cu ft
Nov 28, 2014 | GE Microwave Ovens
Is this model still available for purchase, if not what is the mdl # that replaced it?
Brenda, according to the GE website, that model is no longer available. They do have other models of similar size though. I have included a link to their website for that size microwave. Products from GE Appliances
Nov 17, 2014 | Microwave Ovens
JVM1331WW 002 What is the cu. ft.?
The "13" in the model number means it's a 1.3 CF model.
GE Customer Service (here) can tell you if they have a "drop-in replacement" model.
Apr 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Need mounting bolt sizes for GE Spacemaker Microwave oven, model jvm1440bd003, thanks!
see your instruction manual. download from www.fitness.manualsonline.com or www.retrevo.com and proceed according with common sense
God bless you
Jul 19, 2012 | GE Microwave Ovens
Need installation bolt sizes for GE spacemaker model jvm1440BD003 microwave oven
download the instr. manual from www.fitness.manualsonline.com or www.retrevo.com and proceed according.
God bless you
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Compatible replacement
GE Customer Service is here. They can tell you if they have a comparable "drop-in" replacement.
You can usually find helpful exploded view diagrams and order parts & accessories by entering your full model number here.
Nov 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
