Question about KitchenAid Refrigerators
How to remove ice maker kfis20xvms - KitchenAid Refrigerators
Kitchen aid model kfis20xvms4 will not cool and front screen lights up but no words
Bad cold control sounds like. Try unplugging from a while n plugging it back in
Oct 24, 2016 | KitchenAid KFIS20XVMS 20 french door...
Icemaker will not restart
1 Lower the bail wire to turn on the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Apr 10, 2015 | Refrigerators
Why won't the ice maker shut off even when I shut off the switch? The ice maker does not use a shut off arm or lever
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
Sep 05, 2014 | Kenmore Refrigerators
Ice maker won't shut off
Jan 26, 2014 | General Electric GSH25JFX Side by Side...
REPLACE ICE MAKER PART AP4345120
Remove the ice bin. Remove two screws, holding the ice maker and unplug the power cord. Remove the ice maker.
On the new ice maker install the water chute (plugs in) and install the new ice maker.
Mar 13, 2012 | Refrigerators
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Sep 20, 2011 | Amana AFF2534FE Bottom Freezer French...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
