Question about Samsung Prostar 816 Phone
Telstra v1600 sms
I need new batteries,where can I buy them.I have tried several types which don't work
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Can't stop TNP wap mounthly ringtone
Try this SMS fun.poly.off to 176 or Log on to es.telstra.com/PocketNew...erts_Summary.jspextlink.gif and deselect the alerts you have selected , you will not be charged for using this service.
Hope that helps...........
Aug 08, 2008 | Lands Phones
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
Cant send or receive mms on phone. still wants telstra but im optus now
Depending on what type of fone you have there is a setting in:
Messages/Message Settings/SMS-MMS
In here you will find a command called MMS Centre.
Simply change this to that of your service provider and activate.
Rgrds,
May 28, 2010 | Cell Phones
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
RX-V1600 2 clicks but won't switch on
I have the same problem, any resolution on this one yet?
Nov 13, 2009 | Yamaha RX-V1600 Receiver
8100 pearl
I am getting that the system used by telestra is not compatable with that blackberry you had there. Even though it may be unlocked diffrent systems do use diffrent Gprs chips in witch nt only will it need to be unlocked it will need to be registered with telstra as well.
Jul 01, 2009 | RIM BlackBerry Pearl 8100
Working less than 12 hours
tyr to change ur charge
May 09, 2009 | Nokia Cell Phones
Samsung SGH-A411 Network Unlock Codes
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Dec 24, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Lands Phones Logo
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
