Question about Westinghouse 32 LD-3265 720p Widescreen LED LCD HDTV - 16:9
Daijitsu tv - Westinghouse 32 LD-3265 720p Widescreen LED LCD HDTV - 16:9
Need cod for a daijitsu tv remote had it can use it trying to use universal remotenot working
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 01, 2017 | Universal Televison & Video
I have a daijitsu tv cannot find cod
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
Jan 01, 2017 | Televison & Video
Any one know code for a daijitsu TV please
There will be no code to this TV. It is not a branded one. It is an "Akri". Throw it away man.
Aug 27, 2016 | Televison & Video
Hi , i have a DAIJITSU LCD42HWA TV and i brought a AUDIOSONIC Universal Remote JLR-6005 and i can't find a start up code anywhere. Can anyone help me out plz . Thnx Geoff
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Mar 30, 2016 | Universal Televison & Video
Looking for remote control/tv code for DAIJITSU LCD HDTV MODEL:LCD42HWA.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Nov 11, 2014 | Televison & Video
Daijitsu n13174
Check to see if you have the right outlet and plug. You should have no problem wiring it,fairly easy task! Make sure you have the right voltage parts!
Jan 14, 2014 | Heating & Cooling
Tv wont turn on
It sounds like a main digital board fault. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
Daijitsu split system out side unit not turning on.fuses ok,has little red light flashing.do you know what to do..thanks
you turn on the unit. let the little redligth on for about 10 minutes may it changes his operation. conduct observe the unit to on if not check the thermistor plug in tightly it is connected to PCB board or replace it
Jan 30, 2011 | Frigidaire FRS09PYS1 Split System Air...
Westinghouse 32 LD-3265 720p Widescreen LED LCD HDTV - 16:9 Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
