Question about Philips DC291/37 - Ipod Iphone Ipad Docking 2 X 5w Rms Mp3 Link
I need to open a philips alarm docking station DC291 to replace the connector in the dock station. I can't figure out how to open it.
2 Suggested Answers
SOURCE: cd stuck in philips dcm 230
I had the same issue today and came up with a solution...maybe not the best, but it worked. I unplugged the unit and then holding it by the sides (which I was sitting down) struck (not too hard) the unit onto my knees. Be sure you are holding the unit with the CD opening facing the floor. You may have to do this a few times, but the CD should start to come out, after which you should be able to grab hold of the disc and pull it gently out. Once I did this, I inserted another CD and everything worked fine. Being the daring type (obviously), I tried the original CD again, and like the first time it got stuck again and I had to repeat the same process. I came to the conclusion that for whatever reason, the CD was bad and tossed it out. Any other CD I put in the unit works just fine. Bottom line, it may be crude, but it works!
Posted on Jul 21, 2010
Philips device won't recognize when docked.
Remove cable from the docking station and plug it directly in to the LFH9600
dictaphone if the system communicated it is possible that the docking station is bad.
Jul 17, 2012 | Philips LFH9600 Digital Pocket Memo with...
Edifier brand docking station works with my ipod nano with auxillary cable but will not work in the docking port - no sound and no charging. Please suggest a solution. Many Thanks Stephen
There might be some issue with the docking ports. Try to connect a different iPod and see if its working, if its not working then there is some problem with the Dock connectors in the docking station.
Oct 10, 2010 | Audio Players & Recorders
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
Dock station for hp pavilion
You need to check the plug that plugs into the laptop to determine that you don't have a faulty lead or plug. Test it with a multimeter and wriggle the plug to see if the voltage reading remains steady. If it doesn't then it could be the lead and this is easily repaired.
You may be able to borrow an adapter to test your laptop's connector.
If you determine the fault is with the laptop then problem is most likely the connector socket on the laptop, it most likely need re-soldering onto the motherboard, or needs to be replaced. This requires the laptop to be dismantled completely.
A docking station would solve your problem because the docking station has its own power connector and you plug the existing power adapter into the docking station.
My HP is connected to a docking station, the other advantage is that the docking station has several more ports than the laptop which is useful.
Feb 12, 2009 | HP Pavilion dv6000z Notebook
Jensen JIMS-225 instructions
while the docking station is in sleep mode or off not playing any music on the remote click the set button twice an alarm clock icon will appear and you use the volume buttons and the skip track buttons to set. To turn the alarm off hold the snooze button down until icons disappear. I lost the english version of my instructions but still have the spanish and can kind of figure out what it says still. Hope this helps
Dec 23, 2008 | Audiovox Jensen Universal iPod Docking...
Bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
http://www.chargeconverter.com/shop/connector.htm
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Nov 26, 2008 | Bose SoundDock digital music system...
Cannot open im600
I own the im600 and I have managed to take it apart far enough to fix it. I saw no screws to open the system, but I saw that the grille was loose, so carefully I took it off using a tweezer with a sharp point (sticking it in the holes is the grille near the edge, using the tweezer as a lever) after some time the grille was off. After that I could take the speakers out etc. Maybe this could help you. Only thing is that I haven't figured out yet how to open the whole system and exposing the circuitry etc, it stays stuck at the display somehow (if you figure it out, please tell me )
Nov 14, 2008 | Altec Lansing Inmotion-IM600...
Docking
store.philips.com
They may be out of stock. You may even have to purchase a Philips home theater system with GoGear docking station to get one - you cannot order a separate dock right now, as they don't sell docking stations separate from the home theater system.
Dec 30, 2007 | Philips GoGear HDD1830 MP3 Player
Philips DC291/37 - Ipod Iphone Ipad Docking 2 X 5w Rms Mp3 Link Logo
47 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
