Question about Shakespeare Spiderman Fishing Accessory Kit for Kids 97785
Fishing line broke - Shakespeare Spiderman Fishing Accessory Kit for Kids 97785
My grandchildren broke the fishing line and wound it up inside the reel. How do I pull the line out to retie the bobber.
Hey Carmen,
Depend on what type reel... a spin cast usually has the ability to remove the entire face or cover of the reel...
Look yours up on here....
http://www.reelschematic.com/#gsc.tab=0
Aug 20, 2017 | Fishing
What lb test fishing line does the 112 Oceancity fishing reel take ?
Is this the vintage 112 casting reel?.. You can use almost any size line that the reel will comfortably handle... too small and you might lose fish..and take miles of line to fill..... and .. too big and the reel will not function efficiently..its almost a judgement call.. use common sense..If you need a very small line.. you should use a "backer" to keep from using 1000's of feet of line to fill the spool..... and .. If you need a very heavy line... maybe a bigger reel is in the future... hope this helps..
Jul 22, 2017 | Fishing
My fish tank air pump broke and I think my fish aren't getting enought oxygen because of it. Should I buy a new one or can it be fixed?
Technically, it can befixed but if it happens once, it will likely happen again. You should buy a new one as they aregenerally pretty cheap. In the meantime,fill a large bowl with water and place the fish there. This will allow them to get some fresh oxygen. While the fish are in the temporary container,get rid of all of the water in the tank. Then, refill again with new, oxygenated water. I wouldn't leave them in this environment formore than a day before you purchase a new air pump.
May 13, 2012 | Fish
A string broke, space bar and platen does not work.
The tab cord is probably what broke. If it a string some 50# fish line will probably work.
DickyO
May 13, 2011 | Royal MS 25 Typewriter
Wii bass fishing
u can order one from online at Amazon.com or Walmart.com
Jul 16, 2010 | Sega Bass Fishing for Nintendo Wii
How do you replace the gas line on a McCulloch chain saw? When I try to pull out the filter the line broke. chain saw
use a pair of long needle nose pliers to get the filter out then fish the new line threw the hole and put filter on the end o of the hose and pull it into the tank with it laying in the bottom, then cut the hose and slide over carburetor.
Nov 24, 2009 | Electronics - Others
On my craftsman gas edger, the fuel tank has 2 holes on bottom, my fuel lines broke. i bought new lines but how do you install the lines do you put a fuel line in each hole or do you use tine same line and...
Hi ken If your machine has 2 holes in the tank it must have a primer first of all you you must fish out the pick up filter from the tank feed your new fuel line into one hole and out the filler hole connect the filter & put it back in that line goes to the bottom of the carby the next one from the top of the carby to the primer then from the primer back to the tank.
Jul 10, 2009 | Garden
Bobbin
have good eye hand cordination and lick the end of a perfectly cut thread up to the bob make sure not too have any loose thread on the end or will not go threw
my mother when i was little taught me to sow on and old 32 singer up her new 65 singer when she bought it used i never could use the stick to sow
or you can cut a piece of fishing line little fast acting glue to the ends together or grease thick sowing grease this will keep fish line and thread together as your putting in bobbin
fishing line about 1/2 foot piece
May 16, 2008 | Brother LS-2125 Mechanical Sewing Machine
Shakespeare Spiderman Fishing Accessory Kit for Kids 97785 Logo
19 people viewed this question
Top Shakespeare Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Toy Expert? Answer questions, earn points and help others
