Ubee router cant connect chromecast dongle to network. says upnp needs to be enabled. went to settings page for router & there is no option to change that. HELP! What's wrong with this thing? What can I do????
5 Suggested Answers
SOURCE: BEFSR81 admin problem when enabled uPNP
I actually FOUND the solution at the linksys community forum site. It's weird, and I quote [kiefmoon], "I beat my head against this issue for the past few months, for the same reason as you: I'd built out a Windows Home Server, which can configure a home router automatically via UPnP, so I happily enabled it on the router, only to be locked out of the web-based configuration page.
Good news though! I just figured out the cause of the issue -- and it's really dumb:
You turn on UPnP on the Passwords tab, right? Well, if you look around on that page, you'll notice that, along with the option to enable UPnP, there are two password fields filled with asterisks. I think most people would assume that if they don't change anything in those fields, then click Apply, that the password has not been changed. And they'd be wrong. I don't know what the password gets changed to at that point, but it's not "admin".
...So the fix is: when you enable UPnP, do yourself a favor and enter a password in those fields (ideally something sronger than "admin" ). That way, you'll actually know what the password is when you get prompted for it."
Posted on Jun 16, 2008
  • 154 Answers
SOURCE: how do i change my nat type from strict to open
I have the same router and the info acertempest gave you should work.
However, in my case, I found it did not work. I had to go under applications and gaming, select Port Rang Forwarding and then open the following ports:
TCP 80
UDP 88
UDP 3074
TCP 3074
UDP 53
TCP 53
Once that was done, I had to configure one of the gamertags to automatically sign in to Xbox Live (as crazy as that sounds) when the console is turned on.
Posted on Jul 17, 2009
Tom Marvolo
  • 708 Answers
SOURCE: enabling uPnP
Open the RSP by typing 192.168.2.1 On the Address bar of the internet Explorer
On the left side under utilities Click System Settings
you can Enable UPnP in this Page
Posted on Jan 07, 2010
  • 10 Answers
SOURCE: hey bro i have 2
The best way to allow all servers to be seen is the put your XBOX onto the DMZ. The router will only allow you to put one xbox on the DMZ, look in the router settings and add the IP of your xbox. You may want to first assign a static IP to your xbox instead of an automatic one.
Posted on May 06, 2011
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
Xbox nat setting moderate; NEED TO ENABLE UPnP
What is the model number of Linksys router.
Connect the computer to the router and open the setup page of the router.
Go to Administration tab. There you will find the option to enable UPnP on the router.
See How to change NAT type to open.
Watch video: How to change NAT type to open.
Feb 06, 2012 | Linksys Computers & Internet
Hey bro i have 2 xbox on one connection and i am trying to change my nat settings because when some one joins my game it says that i have a restricted nat settings i have a ubee DDW3610 i went to the web...
May 06, 2011 | Computers & Internet
My DLink router DIR 632 Disconnects AOL AIM IM every 10mn or so, i tried changing the ports from 5190 to 443 which use to sole an issue of rapid disconnects/reconnects with a previous router...
It can be the router config... or the WIFI dongle/card, if it is the router config, turn on DMZ in your router config if it is your wifi card follow these directions: go to Start > Control panel > network connections > right click on your network connection and then click on properties > a window will open, you'll see the name of the wifi adapter you have click on the "Configure" button right next to the network adapter's name > click on the advanced options tab then through all your advanced options until you find power saving mode than change it to constantly awake mode or CAM, see if it fixes your problem. Have a nice day
Mar 30, 2011 | Computers & Internet
Vizio xwr100 need to enable UPnP
You can get into the router's firmware by typing it's location on your network into your browser bar.
For most people, the address is usually http://192.168.1.1/ .
From there, usually you will have to enter your login & password for the router, and then you will have the option to change it's settings. Just look around and you should see an option like "Enable UPnP?" with a checkbox or a yes/no dialog next to it. Simply check it, save your settings, and close the browser window.
Some routers you may have to power down the router and then turn it back on for the new settings to take place.
Mar 17, 2011 | Computers & Internet
How do I enable UPnP on this router WRT160N
on WRT160N router UPnP is enabled by default.
You don't need to enable it.
If you want to check the settings of the router then you will need to open the set up page of the router. Router set up page is a page where you can check/change all the settings of the router.
Is there any computer connected to the router. Check the Ip address of the working computer and open the router set up page.
Once you open the router seyt up page, click on Administration Tab. On that page at the bottom you will see UPnP. It must enabled.
Click Here for more information about router and
networking
Feb 04, 2010 | Linksys WRT160N Wireless Router
I am having problems with downloads with my WBR-2310 Dlink Router. The downloads are much quicker without it in line. How can I fix this? Do I need to make some type of parameter change within the router...
Yes check this settings in your Router Setup Page.
In your D-Link Setup Page.
Go to Advanced Tab > Advanced Network
Check the following :
Enable UPnP
Enable Wan Ping Respond
( Wan Port Speed - set to Automatic )
Enable Gaming Mode
Enable Multicast Speed
Save the changes.
Jan 24, 2010 | Computers & Internet
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
Enabling upnp
You need to access the router's setup page. The default IP address of Belkin router is 192.168.2.1. Launch IE and type 192.168.2.1 on the address field. It doesn't need a username/password by default. So when a windown pop up asking for one just leave the fields blank and click ok.
Once you're in the setup page, you may now be able to configure the router with the settings you need.
Hope this helps!
Nov 09, 2008 | Belkin Computers & Internet
Computers & Internet Logo
608 people viewed this question
David Payne
David Payne
