Question about Frigidaire FRS23R4A Side by Side Refrigerator
Frigidaire Model FRU17B2JW23 EVAPORATOR FAN REPLACEMENT
4 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
heatman101
  • 43501 Answers
SOURCE: frigidaire frs26r4a the freez and
Either the defrost timer or the door switch...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 20, 2010
MY REPAIRMAN
  • 61 Answers
SOURCE: how do i replace the evaporator fan on frigidaire FRS23R4A
REMOVE EVRY THING ON FREEZER TAKE ICE MAKER OUT IF APPLY REMOVE BACK PANEL AND REMOVE FAN AND BLAIT AND INSAL NEW FAN AND REVERS STEPS
Posted on Feb 22, 2012
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
Model fsc23f7dsbc ref replaced control board now ref flashing e f
Good Afternoon friend, thank you for your inquiry!
Based off the information you have provided you replaced the control board and continue to experience troubles with your Frigidaire refrigerator. Normally an "EF" error code stands for evaporator fan circuit failure. This could be an issue with your evaporator fan or main control board. I would suggest consulting with a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this helps to some degree. -Matt
Sep 24, 2014 | Frigidaire Refrigerators
Evaporator fan is not working and temp in freezer is not working but the coils are working
You will need to replace the evaporator fan assembly. I didn't see your model number posted but here is a link to the Frigidaire fan kit that should cover all models.
Sep 03, 2012 | Frigidaire Refrigerators
Frigidaire custom imperial 170 manual
replacement compressor for frigidaire refrigerator freezer Custom imperial FPCI-230v3 (20.3 ft vol)
replacement evaporator fan and condenser fan
Jun 11, 2012 | Frigidaire Refrigerators
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
How do I change the evaporator fan motor in a frigidaire model FRS20WNF side by side refrigerator?
This link should be close Evaporator fan replacement You can also enter your model # for diagrams and illustrations of your specific model.
Dec 01, 2010 | Refrigerators
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
MY BROTHER HAS A FRIGIDAIRE REFRIDGERATOR MODEL NUMBER. FRS3HR5HW3 AND IT IS MAKING A GRINDING SOUND KIND OF IN THE FREEZER. WAS WONDERING WHAT IT CUD BE AND HOW TO FIX IT.
I am having the same problem. I had a technician check it out and he replaced the evaporator fan motor. A month later the noise returned. The technician came again and said the cause was the water valve freezing and the ice buildup hitting the evaporator fan. I am having my brother repair it this weekend. The cost for the tech. was nearly $300, almost a third the value of the fridge. I, personally think there is a design flaw in the refrigeration system.
Apr 29, 2009 | Frigidaire Model: FRS3HR5HW
Frigidaire FRS23R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
