Question about 2wire 2700HG-B Router (2700HGB)
Occasional reboots the 2wire 2700hg i have setup at home seems to be restarting every 10 mins or so (at first i thought it was just lag spikes). all the lights go off and leave just the power light on. a manual reboot of the router did not fix this. it has been installed and working fine for a few months, could it suddenly become faulty?
  • 3 more comments
  • Aximand Sep 03, 2007
    is there a way i can set it so it doesn't try to change connection speeds?
    thats brilliant cheers
  • cooldeals Nov 02, 2007
    My 2Wire router keeps on rebooting itself very frequently. I haven't used it for 5 minutes without it rebooting........is it something to do with the firmware
  • pArKeL Oct 30, 2008
    same problem...
    changed the modem 2 times wif singnet... and it still keeps happening... usually after 1 to 2 months and the thing would start all over again.
    i called up singnet and they said to take the modem to
    76, Playfair Road, LHK 2, 06-03
    opening hrs r from 9am - 7pm.
    thats where they produce the 2wire modem.
    anyway.. mine is 2WIRE 2701-HGV-E (tats the one im using now)
    the previous one: 2WIRE 2700-HG-B-2
    I have the same problem here...
    i called up singnet and they said to go to this: 76, Fairplay Road, LHK 2, #06-03
    opened from 9am to 7pm to change the modem.
    there were 2 modems with the same problem and both were different models.
    the 1st one (previously used) was 2WIRE 2700HG-B-2
    the 2nd one (currently using) is 2WIRE 2701HGV-E
    President:
  • 2,961 Answers
I too have found this problem with the 2 wire 2700 and found that if the router tries to alter the connection speed and finds it cannot connect at the faster speeds it has to reset itself to revert back to a slower connection speed, so keep an eye on your connection speed which can be found in the routers settings on the initial page and check if the speed registered is faster than that of which your line can carry, if so then you need to contact your isp.
Posted on Sep 01, 2007
  • andrew pester
    andrew pester Sep 03, 2007
    Unfortunately it's the phone line that sets the speed because of the distance from the exchange to your home, but you can try altering the MTU setting in the routers menu it can be found in Broadband Link section and click advanced settings and bottom right hand side of menu saying force upstream mtu.
    This will probably be set at 1500, you can reduce it to 1493 but it may not work its any number between the two that may get the correct speed, but really the speed should be fairly constant, if not you should speak to your provider as they control the speeds from their servers.
Question - Can you have two 2wire routers in one house?
yes but you will have to change the channel in setup on the router then change witch router your computer hooks up to
Feb 17, 2010 | 2wire 2700HG-B Router (2700HGB)
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
CAN I USE A WPA2 SECURITY WITH THE 2701 2WIRE B-ROUTER
It only supports WPA and WEP. If you need help setting it up, here is a great guide: http://server-servers.com/att-dsl-2wire-2700hg-b-router-setup/
Good luck
Dec 28, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700hg-b modem/wireless router, my problem is i get lag while playing xbox 360 online, i get red bar to none , while my friend have all green bar,in the tv screen,also my laptop lose signal...
yeah a better modem would be the easiest thing to do because it's clear that the one you've got is either not transmtting properly or is just the unit you'vee got has a fault in it
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless system strength on laptop away from router
I don't beleive it's your dsl, It seems to be a problem with your router, since it sounds like it is not broadcasting well. Consider a new router before ridding of your ATT DSL.
Apr 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Connection to my computer of hp photosmart c6300 via belkin adsl2router
3. Open IE beoswer.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
Dsl modem 2 wire is losing power
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
Jul 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Wireless issue.
3. Open IE browser.
6. Log-in with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
For a more detailed first time install no software needed check this link:
http://www.dslreports.com/faq/14083
Enjoy!
please vote...
Feb 06, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
880 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
