Question about Brookstone MiniMax Tower Fan
How do you clean a Brookstone mighty max tower fan
My Brookstone PureIon Advanced air filter is stuck in TURBO mode and I cannot get it to slow down! how do I UN-stick it?
Sounds like the control is damaged. You could try calling Brookstone service and see what they say (they have a one-year warranty). Number is 1-800-292-9819.
Aug 12, 2016 | Brookstone Air Purifiers
What years are the windshield for a 1990 Mitsubishi mighty max interchangeable?
Mitsubishi Mighty Max Parts & Accessories - JCWhitney
www.jcwhitney.com > Mitsubishi
Below you'll find a wide variety of Mitsubishi Mighty Max parts and accessories. Enter the year of your Mitsubishi Mighty Max to get a more customized product ...
Mitsubishi Mighty Max Cars and Parts ' eBay
www.ebay.com > eBay Motors > Cars & Trucks > Mitsubishi
eBayResearch Mitsubishi Mighty Max popular models, prices, photos and read reviews. ...Tell us what you thinkthis item - opens in a new window or tab. Mitsubishi Mighty Max. Share: Mitsubishi Mighty Max Model Years ... Mitsubishi Mighty Max · 1990 Mitsubishi Mighty Max · 1989 Mitsubishi Mighty Max · 1988 Mitsubishi Mighty ...
Mitsubishi Mighty MAX Parts, Mitsubishi Mighty MAX ...
www.carparts.com > Mitsubishi
Through the years, your vehicle's components will succumb to wear and tear, ... In addition to replacement Mitsubishi Mighty Max parts, you may also want to buy ...
Jan 11, 2016 | Mitsubishi Cars & Trucks
What is the torque for installing the crankshaft for the 2.4 mitymax motor?
Mitsubishi Mighty Max crankshaft bolt Questions & Answers ...
www.fixya.com > ... > crankshaft bolt > Cars & Trucks > Mitsubishi
Mitsubishi Mighty Max cars & trucks crankshaft bolt questions and answers. ...Torque specs for mighty max The head torque specs for 1991 mitsubishi mighty max 2.4 I ... 1989 mitsubishi 2.0 motor crankshaft was turned while timeing belt was off. ...how to install a clutch kit on my 1994 mitsubishi mighty max Disconnect the .
Oct 02, 2015 | Cars & Trucks
Mitsubishi mighty max 3.0 v8 loud noise coming from the fan area
If the fan is attached to the water pump tahe hold of a blade and try back and forward towards the motor. If there is movement there it will be either a fan hub failing or a water pump bearing. Second check remove the fan belt and check for noise.( idle engine for short period of time) If it is gone confirm pump by spinning any adjuster pulleys and check for noise or rough movement
Jan 12, 2013 | 1994 Mitsubishi Mighty Max
I need to take the fan apart to clean all of the dust inside. how do I do that
You will need a phillips screwdriver (preferably 2 different sizes - some of the screws are tiny), q-tips and a can of wd-40.
On the back of the brookstone (the darker gray side) you will find 4 screws inside of 4 channels. Take these out.
Put the fan on its head. pry off the 5 rubber bases and set aside carefully so as they won't lose their stickiness. You will see 5 screws beneath these. Remove them and then remove the bottom plate. Now remove the 2 screws and washers, noting that the rounded side of the washer was facing you. Now pivot the base so that the 4 holes on the outer part of the base line up with the 4 screwsheads that are screwed into the tower. Take these out.
The 2 gray tower pieces should now separate easily. set the fan on a newspaper and blow away as much of the surface dust as your can. Now use your wd-40 (with a straw nozzle attached) and spray into the motor area where the actual fan turns. Also spray, from the top down, along the metal rod that connects the fan to the motor.
Now use the q tips, dipped into warm water, to clean the dust from the fan "blades" and to clean any other nooks and crannies you can see.
Lube the motor up one more time, put the machine back together and leave to dry out overnight.
Will work like a charm afterwards.
Jul 07, 2011 | Brookstone MiniMax Tower Fan
Could you please tell me the firing order for a mitsubishi pajero 3ltr v6
There are 2 3.0L engines used in 1989. One has a flat distributor cap with the plug towers coming out sideways and the other has a conventional cap with the plug towers protruding vertically. Both have a firing order of 1-2-3-4-5-6 (Gee, that's hard one to remember!... LOL ;) ) The ditributor cap should have the cylinder numbers cast into it at each plug tower - most Mitsubishi caps do. The cylinders are numbered 1-3-5 on the right bank and 2-4-6 on the left bank.
Apr 20, 2011 | 1989 Mitsubishi Mighty Max
Mighty max pk parked two years and wont start. it turns over
firstly drain tank and refill with fresh petrol then try but you may have to remove fuel pump and clean it it out of the clag?' but it may be ok with just changing the petrol ,try it first
Mar 01, 2011 | 1990 Mitsubishi Mighty Max
Fan does not come on because fir needles have clogged it up. How do I clean out fir needles?
TRY A SHOP VAC REMOVE FAN VACUUM OUT FIR NEEDLES THEY COULD CAUSE A FIRE HOTWIRE FAN TO SEE IF IT WORKS BECAUSE YOU COULD.HAVE A BLOWED FUSE/RELAY.
Aug 26, 2010 | 1990 Mitsubishi Mighty Max
Brookstone MiniMax Tower Fan Logo
78 people viewed this question
Top Brookstone Dryers Experts
Are you a Brookstone Dryer Expert? Answer questions, earn points and help others
