Question about Craftsman Garden
I am looking for the fluid capacity of a hydro gear transaxle model 314-0510 in a model 917270940 craftsman riding lawn mower
I need to know how much 20w/50 oil I have to put back in a hydro gear transaxle model # 314-0510 that is in a model # 917270940 craftsman riding lawn mower
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Posted on Aug 23, 2010
SOURCE: Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Posted on Aug 05, 2012
  • 4961 Answers
SOURCE: riding lawn mower hydrostatic drive is jerky like it is sliping sears model #917273780
You might want to re-post this question in the lawn mowers section.
Posted on Aug 18, 2012
  • 4961 Answers
SOURCE: I have modle number 917273201 riding lawn tractor I need the part number for the splined couppler that goes between the hydro output shaft and the transaxel input shaft? Thanks
You might want to post this in the lawn mower section so the proper experts will see your question.
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Gear shift lever is loose and mower will not move. this is on a craftsman lt1000.
Trace back the linkage from the shift lever to the transaxle to see if the linkage has come apart. If it is a manual, then I know the linkage connects to the transaxle on the top, forward, left of center. There is a retaining bolt (i think bolt, been a long time) that attaches the linkage to the transaxle. If this has backed out very much the linkage is not going to shift gears on the transaxle.
I hope this helps.
Jul 28, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower start but it wont move
Is it a Hydro, or belt drive?
Is Hydro on bypass?
Is the belt off, or broken?
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No manual for Husquvarna ride on mower model 4140H
Don't know if this helps but the owners manual for my Husq YTH2148
indicates that the transmission fluid is not to be changed, ever. If there is a problem, the whole unit is to be replaced.
These mowers, along with many craftsman rider mowers, are actually made by Roper. Perhaps if you googled around a bit you could get more info relating to service of the transaxle.
Apr 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman riding mower stuck in 3rd gear
you have a broken shifting fork in the transaxle, i know this, i just replaced one on a mower that was stuck in third gear...
Apr 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Apr 06, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
