I have a whirlpool duet washer WFW8500SR01. The door won't unlock and the cycle wont finish.
Master_Tech
  • 770 Answers
SOURCE: whirlpool duet washer
I will need the model number off the unit on a regular Duet there is no F-01 codethere is a F10 some models (ie. Sears units) have diffrent codes so if you post the model number i can see where the problem lies also if you need to open the door there is an Emgcy. door release it is located behind the lower panel you will need to remove the 3 #10 torks screws the panel will come off reach up below the door latch assby you will see a tear drop plastic tab pull on it and it will release the door
Posted on Apr 21, 2008
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
  • 53 Answers
SOURCE: My whirlpool duet sport washer often finishes it's
Slow drain. Check your drain hose for kinks and make sure it's not partially plugged. If it is going into a pipe make sure it isn't pushed too far into it.
Posted on Sep 11, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
localwonder
  • 6784 Answers
SOURCE: washer giving F2 error during wash cycle, cycle doesnt finish
Potential Causes
Posted on Oct 26, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
Whirlpool duet washer wont star after clean cycle was run.in fact, im not even sure if the clean cycle cycled all the way through. front wont light up or anything.door was locked but got it unlocked by...
Those parts are not from the washer. The trap is before the pump so that is a good thing. Most likely the switch to the door is not working or the control board is bad
Nov 26, 2012 | Whirlpool Duet GHW9150P Front Load Washer
It keeps starting at the beginning of a cycle, won't finish, and can't open the door
1) YOU MUST test the TIMER for defective, test the contacts dirty, or oxide.Loose wire, or open or break.
see the diagram
2)see if the screen is clogged+ test the defective water inlet valve see how to test.
Jun 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Cycle is finished but door will not unlock how do i unlock the door
you have three screws to take off the bottom panel and you reach in and pull on a little loop on the door latch
Jun 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool wfw8500sr01 door locks and does not start F24 f26 f28 error codes
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa&^%
Dec 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not unlock on my whirlpool washer wfw9200sqa
Power must be on. Hold down the 'end of cycle' button at the right side of the panel for 3 seconds. Wait for 2 minutes then try the door.
Mar 22, 2009 | Whirlpool WFW9200S Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
