Question about Compaq (480082-001) ( 480082-001 ) Power Supply
Power supply does not fit!
Hi, Trying to dress up my daughter's computer. Attempting to put her older Compaq MB and drives into a CoolerMaster case. All is going fine, but the power supply does not fit the screw holes in the Cooler Master case. Is the Compaq PS a different type? If I buy a new power supply, what type do I buy? Thanks for any help, BarnBurner
  • Compaq Master
  • 12,061 Answers
OK most PSU's are the same.. by that I mean as long as the output & connections match, then the size & shape don't really matter. On the PSU somewhere will be a "Wattage" rating say 250Watt... whatever.. simply obtain a standard (Usually 350Watt) PC Power Supply Unit (PSU)of the SAME or HIGHER Wattage rating & also ensuring the Mating Connector onto the MotherBoard is the same... ya be all good..
Posted on Sep 22, 2007
SOURCE:
How do I replace the power supply, and can I use one from an SR1738NX?
Before attempting to replace the power supply, I would check to see if they are compatible. I would check to see that the wattage of the Compaq Presario SR1738NX is the same or larger than what is in your current computer. This information should be on the label of each power supply.
Next, I would check the connectors to ensure that all the connectors that are currently connected exist on the old power supply.
Next, take pictures of all the power supply connections on your new machine.
Finally, remove the power supply from your new computer, replace it with the power supply of your old computer, reconnect all of the connectors, and turn on the machine.
Good luck,
Paul
Dec 21, 2015 | HP Compaq Presario SR1910NX (EX310AA) PC...
What power supply is compatible with cooler master cac-t05-uw? \
Good Day
The same model also comes standard with a 390w power supply. However it all depends on what you are using the Desktop for, what you want the power supply features to do and what you install in the casing. Amything above 390w will do for general desktop work. If a gaming desktop, anything above 500w should do. You should obviously use the same brand Cool Master power supply but most brands should fit. Take a picture of the back of the case where the power supply fits and take it with you to a store if not sure.
here is a ling to give you some ideas. http://www.coolermaster-usa.com/category.php?category_id=22
regards
Shaun
Jul 14, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
ATI AGP card and Compaq Presario S3100NX with open AGP Slot
This particular model of the system is basic home use system not built for games.
You can put in either a PCI graphics card or an AGP 4x graphics card that should not take more than 1.5v of power.
The max you can put is 128 MB , you can try the 256 MB, but i would suggest against it .
Thanks for using fIxya
proton
Nov 07, 2009 | HP Compaq Presario S3100nx (DC477A#ABA) PC...
Hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Aug 02, 2009 | HP Compaq d530 SFF PC Desktop
Finding the exact model number and manual for my MB
Hi there.
Is this your board>>>>>>>
If so they are not cheap to replace, about $150+ , you may get one second hand a bit cheaper, maybe $60-80
You mentions it beeps, the beep codes described is a Video (Mono/CGA Display Circuitry) issue
this can be memory related, so take out the main power supply (the power cord) and the motherboard battery for an hour, then put back in the memory, the battery and then the power cord and try to boot up.
Post back if you need help.
Good luck
May 29, 2009 | HP Compaq Motherboard
Needing to plug new power source to motherboard, need the diagram format
the easyest way to do it is to open up the side panel of the computer rite down the info off the side of the power supply such as voltage and so on then go out and buy the same type then as you pull out a plug from the one in your computer put in the same plug from the one you bought and you should be rite, theres nothing that technical you need to no just disconnect it from the power and pull out the plugs its that easy
May 29, 2009 | E-Machines eMachines Desktop PC
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
Powe Supply Problem Compaq
I did some research and the powersupply for that machine is a standard ATX powersupply, so yes just about any off the shelf power supply will fit and work. They may be overkill but that's fine.
HP sells the proper power supply for your machine for $98US as part number 176764-001 . There parts store is at http://h20141.www2.hp.com/hpparts/default.asp?mscssid=CADCEXJ9VLH69MBBGJ8N6SELXQ2C2XP1
Jan 11, 2008 | Compaq 187498-001 Motherboard
Compaq (480082-001) ( 480082-001 ) Power Supply Logo
246 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
