Question about Samsung Sde-3003n 4 Channel Dvr System, 4 Ir Cameras, 1tb Hdd Sde-3003, Warranty
No HDD installed? what thats mean - Samsung Sde-3003n 4 Channel Dvr System, 4 Ir Cameras, 1tb Hdd Sde-3003, Warranty
Troubleshooting acer
this either means that their is no OS, the master boot record is corrupt or your HDD has a fault.
so lets start off easily. go into the bios and change boot order to USB or removable disk.
now go online and download Knoppix ISO image and universal USB once you have both you will need a USB if you downloaded the DVD version you will need at least 4gb if you picked the cd then only 1gb.
using the universal USB installer install Knoppix to the USB and then boot to that, if your pc picks it up and takes you to a desktop then we can say that the PC itself is fine.
next thing to check is that the HDD is their so navigate to it and once their copy your files off (if you can) if you cant then it is potentially a dead HDD which means buying a new HDD and a windows install disk or you can use a free OS such as Ubuntu, fedora or even Knoppix (but Knoppix I meant for recovery)
Jan 12, 2014 | Computers & Internet
Why do I lag on ps3
If you mean on online games, it could be your internet connection. If you mean when playing offline, the media could be at fault. You could also try a faster HDD in your PS3 and install your game into your HDD.
Oct 22, 2013 | Video Game Consoles & Games
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
When I reset My HP Pavillion 9728ca, it would not turn back on no lights no bells or whistle at all then a few day latter in tuned back on???? Then it happen again but it didn't turn back on until a few...
what does RESET mean. tell the helper that first.
my guess is you mean BOOT?
first take out the relic battery (i bet its old and shorted)
does, BIOS work now, hit the BIOS key? yes/no
does it boot to the hDD, now?
To installed W7, Who's, Microsofts or HPs' latter works other dont.
using CD driver to install w7, that it?
does the CD boot and run and ask all the normal questions?
it takes a good HDD to installed W7.
for a fact.
I test the PC with a Linux live disk or Windows PE live disk
first to see if all is good, then run HDD tests from there.
using HDD test software, (free from hundreds of sources) ask
then install w7, when sure.
battery is out.
power pack ok.
and HDD ok.
only then can it work. (if luckly , )
May 21, 2017 | Compaq Pavilion ZT3280US Notebook
Hdd stuck while installing os
You mean that you cant install the OS???
Then reinstall it and this time change the size of the partition of the disk. And also clean the CD up - down and right - left way. Not in circular way as we mostly do it.
Jan 10, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
I'm getting a PXE-061: Media test failure, check cable. message what do I do?
That message means that the machine can't find any OS on the local drive, so it's trying to boot from the network, and no network cable is attached.
The most obvious possiblities are:
1) There is no OS on the HDD
2) The HDD is not installed or not installed correctly
3) The BIOS boot order has the network boot before the HDD
Jul 04, 2009 | Computers & Internet
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
Dell Latitude C610 PC Notebook Problem
With your indulgence may I clear something, you installed a new 60Gb HDD to your Dell Latitude C610? If yes, then you would need to partition, format the new HDD and install an Operating System.
If on the other hand the 60Gb is the original HDD, then it could only mean that the HDD is defective or that its files have been corrupted and likewise would require an re-install of a clean, fresh OS. In some instances, a repair could be done but the same would need the use of a recovery CD or a Windows installer of your choice.
There would be no limit to the capacity that you can install. The only limitation would be the physical dimensions and the way it is electrically connected internally to the laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Dell Latitude C610 Notebook
Question
You mean the setup doesn't load? Also when installing Windows, the first part it copies data to the just formatted harddrive. Then it reboots, but make sure it doesn't reboot from CD because then it wil start all over again. It must boot from harddrive after it copied files to your drive.
The setup data is located on you HDD from that moment on.
Or isn't this what you mean?
Greetings,
DarkNeogen
Jan 24, 2008 | Maxtor Hard Drive
Samsung Sde-3003n 4 Channel Dvr System, 4 Ir Cameras, 1tb Hdd Sde-3003, Warranty Logo
252 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
