Adjusting margins for avery 1562 labels - Computers & Internet
  • 112 Answers
SOURCE: paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Posted on Jan 15, 2008
  • 157 Answers
SOURCE: want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
Posted on May 19, 2009
SOURCE: Printing Avery Labels
click on "mailings" then labels. Then set up your lables
Posted on May 27, 2009
SOURCE: Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Posted on Aug 18, 2009
jbriner
  • 130 Answers
SOURCE: create labels on Word 7 with Avery 8250 labels
I am assuming that you want to do a mail merge from a list.
If you list is in Excel, you should be able to click mailings in Word. It will take you through the steps to create your set of labels. [It will help with other places for your lists besides Excel, too.
Posted on May 25, 2010
Printing avery labels
You need to check the driver settings inthe printer properties and make sure that you are selecting labels as the paper stock. Often times this will adjust the fusing temperature so the toner is melted thoroughly on the label. You may also check the toner..some compatible brand toners do not do well on Avery labels.
Mar 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
I have avery labels 06107 and am trying to print them in word but am not sure how to set up the margins
I suggest you go to the Avery WEB site and download the Word template for your Avery label. Use this template, enter your text and then print, don't forget to place the blank Avery in your printer.
You can download the templates from this WEB site.
http://www.averyproducts.com.au/avery/en_au/Templates-%26-Software/Templates/?Ns=Rank
Feb 24, 2012 | Computers & Internet
What are the margins for avery 8859 business cards
I used MS Publisher Template 8371 and adjusted the margins to the following:
Margin Guides: (for the individual cards)
Top: 0.2
Left: 0.2
Bottom: 0.0
Right: 0.2
Sheet Margins
Side Margin: 0.5
Top Margin: 0.5
Horizontal Gap: 0.5
Vertival Gap: 0.0
Sep 01, 2010 | Global Star Software ProBiz Business Card...
I'm trying to print the cd label on the label paper but it's offset and won't print in the right area. I calibrated the printer but it still won't work.
Some CD label software allow you to adjust the "overprint" by resizing the image you are printing. If your software doesn't allow you to size your image larger than the label (so it overlaps) try a different program. Look for a setting that allows it to over print. It's not an exact science...you just have to try to make the adjustments you need. There are also different CD/DVD label sheet types where the labels are setup on the sheet differently. maybe a different setup may work better. However, usually Avery is pretty good.
Jun 12, 2010 | Avery DesignPro Deluxe CD-ROM...
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
Dec 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
How do you print divider tabs
Depends on the size of your tabs...
In Microsoft Word:
Pull down the tools menu and select "Letters and Mailings" and then choose "Envelopes and Labels", choose the labels tab, and select "Avery 5836 - Divider -Mtg. Creator" or manually set a height of 0.5" and a width of 1.75".
In any Word Processing Application:
Make a table 10x1, set the row height to 0.5", and then set every other column width to 1.75" and 0.5" respectively with a 0.5" left and right margin, 1.0" bottom margin, and a 2.0" top margin. Add rows until you fill the page.
Hope this was helpful and remember to vote...Thanks
Dec 10, 2007 | HP LaserJet 2200D Printer
Paper feed
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Avery Labels
You could look at your printer settings as sometimes it defaults to letter size instead of A4
Nov 02, 2007 | Computers & Internet
Avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Oct 08, 2007 | Avery DesignPro 2000 for PC
Computers & Internet Logo
David Payne
David Payne
