Question about Refrigerators
Ice maker viking VUIM150DLSS
Hi, Is the evaporator plate nickel or stainless steel? Can I use nickel safe ice machine cleaner on it
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I have the same problem, although mine is intermittent. Apparently it's a problem with the line freezing. For an excellent discussion of the issue, see http://www.askmehelpdesk.com/advice/t-14182.html
Posted on Jan 05, 2008
Templarius
  • 86 Answers
Clean the water disposer
Posted on May 26, 2008
mikedurland
  • 481 Answers
SOURCE: I have a GE Profile
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 01, 2008
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
SOURCE: exterior finish on stainless steel model peeling
Just a thought. Our frigidaire stainless steel refrigerator came with a temorary protective film on the steel parts that we peeled off after it was installed. Is it possible you never removed your film when you got your refrigerator? That may be what is starting to peel off now. Again, just a thought, I could be wrong.
Posted on Sep 02, 2008
Viking vuim150dlss bin t.mister
Do you have a new one? Try comparing the values. There are several types of thermistor. Do you have the type number?
Mar 16, 2014 | Ice Cube Maker
Makes ice for 3 cycles then stops running.Can turn off then on again to make more ice for a couple more cycles.
check the cycle time for a batch of ice. should take around 15 minutes to freeze and then you will hear the harvest cycle kick in. If the harvest cycle takes 3 minutes or more that is your problem. You will need to get a hold of NICKEL SAFE ICE MACHINE CLEANER. DO NOT use CLR or any kind of cleaner other than NICKEL SAFE ICE MACHINE CLEANER. If the ice doesn't fall off of the plate in about 90 seconds either the plate is dirty or the nickel plating has come off. There is a failsafe shut down if the unit takes more than 60 minutes to freeze or more than 3 minutes to harvest 3 consecutive times. The cleaning instructions should be inside of one of the covers. If not it's available online.
Aug 15, 2013 | Manitowoc QY-0214A Self Contained Ice...
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
GE Monogram ZDIS15 has ice (sometimes) getting stuck on freezing plate. It gets hot & tries to release, but only partially (sometimes works fine). I have cleaned with solution, run the cleaning cycle...
It is time to run a ice machine cleaner through the unit, instruction should be on the door. When you get a build up is causes your ice to bind to the evaporator plate and cause this problem. Most ice machines require cleaning every 6 month to prevent this. Use nickel safe cleaner only, and most of the time this will correct the ice binding on that evaporator plate.
I hope this helps
Aug 11, 2011 | GE Monogram ZDI15C Automatic Icemaker
Hoshizaki KM-500MAH is making sliver/chip ice. I
just to let you know you need to use nickel safe ice machine cleaner. and i hate to tell you this but if you are seeing silver chips in your ice your evaporator is shot. even if it is under warranty they will not give a new plate just for the reason of not using nickel safe cleaner. hope this helps you. i have seen this many times as im a service tech. alot of restaurant owners use coffee cleaner and also destroy their plates
Jun 05, 2010 | Hoshizaki Freezer Commercial Ice Machines...
What do I use to clean the calcium deposits in the ice maker? The note inside the machine says to use a bottle of Nickel safe ice machine cleaner by Nu Calgon.....Home Depot doesn't have it....Target...
CLR will work great, just rinse the ice maker very well after cleaning the calcium deposits and throw out the first few batches or bins of ice produced after the cleaning process. Good luck !
Nov 26, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice not releasing from plate on Viking vuim150drss ice maker
HOW OLD IS THE UNIT, AFTER A WHILE THE NICKLE PLATING STARTS TO WEAR OFF THE PLATE WHICH WILL CAUSE THIS PROBLEM AND THEY ARE NOT CHEAP, ALSO CHECK ON THE BOTTOM OF THE MACHINE THERE SHOULD BE A CONTRPL THAT WILL INCREASE THE TIME OF THE RELEASE CYCLE
Sep 27, 2009 | Ice Cube Maker
Stand alone ice maker makes hollow cubes. Any ideas?
Clean the condensing coil. Run ice machine cleaner through the evaporator coil on a wash cycle.
Jul 07, 2009 | U-Line SS95 Stainless Steel
Need to find cleaning solution for clr2060 ice maker. I live in
I recommend using National Chemicals Nickel Safe Ice Machine Cleaner. Catalog Number NS16OZ.
****Warning**** this is a professional product!
Refer to the units instructions on how and when to use the cleaner. Directions for the cleaner amounts are on the bottle.
Go to a local resturaunt supplier and ask if they have any.
Hope this helps and please rate this!
Nov 20, 2008 | U-Line Icemaker
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
