Question about Proform Exercise & Fitness
Automatic shut down
I have a proform treadmill 600c. Today was the first time I took it to 100 minutes. At exactly one hour and forty minutes the treadmill shutdown to zero speed, but the display maintained the distance, calories, etc. Is this an automatic shutdown built in at 100 minutes for whatever reason, or did it just overheat at exactly that time? It started right back up again, but I only ran it for a few minutes after the shutdown.
4 Suggested Answers
SOURCE: Proform CS17e speeds up by itself after 10 minutes.
You probably need a new speed censor. If you bought it new that part should be covered under warranty. www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
ercupa190
  • 12223 Answers
SOURCE: Proform Treadmill L18 Model #831.298070 LED on control board does not work. The incline and speed controls work and the belt works, but I can't see distance, calories or time on the screen. Any
adjust the reed switch, see the diagram attached. clean it. test for open or faulty. Tight the connector..God bless youb08a32ca-0905-44d9-b13c-bf6a3c12b78b.gif
Posted on Apr 04, 2013
ercupa190
  • 12223 Answers
SOURCE: Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
My treadmill stops running after 3 minutes. It shuts down and I have to reset and start over again. After another 3 minutes, it shuts off again.
Sounds like a motor or electrical system cooling problem. Could be dirt or blocked motor. Try Computer air blast can and or a vacuum to clean out motor and electronics.
Mar 04, 2015 | Proform Crosswalk Advanced Cr 525i 525x...
Why does the treadmill stop after about 45 seconds after i get on it?
1) This happen to due the lack of maintenance schedule Normally you must lube after 5 hours of use. So this system protect itselft a shut down. Now you must have a WORN DECK BELT, time to change. it
2) LUBE the rollers bearing
3) Test the bearing from main motor, replace
God bless you
Nov 14, 2012 | Proform CrossTrainer Treadmill
Proform 615 xp won't come down from folding it
I am having the exact same problem with my ProForm 615 treadmill. Spent over an hour trying to lower it.
Jun 23, 2012 | Exercise & Fitness
My proform xp slows below the set speed, the motor wines and after forty minutes starts to smell
Dear Sir:
Please RUN THE software calibration for easy diagnose and troubleshooting, and adjust the speed sensor see the diagram attached.
And you will see the problem with the motor, possible lack of LUBE, and maintenance.Now you test the motor for lubrication and maintenance too.
Apr 20, 2012 | Proform XP Weight Loss 620 Treadmill
My question is, last night, I set the speed to 5mile/hr, the treadmill automatically stopped after 12mins( the belt stop, power was on). and I can not restart it immediately, Then after 5 mins, the belt...
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Jul 08, 2010 | Nordic Track /proform Treadmill...
Proform 760 shuts off after running for 15 minutes. Needs to cool off before it can be reset
my wife has a proform 490gs that keeps shutting off after about 40 minutes by tripping the breaker. what is causing this.
Oct 30, 2009 | Proform 760 CrossTrainer Treadmill
Aug 24, 2009 | Exercise & Fitness
Walking speed for 2 hours and the machine just shut off would't turn back on for 20 minutes why?
The motor has a thermal protection device that will stop the motor if it becomes overheated. Eric
Aug 04, 2009 | Nordic Track /proform Treadmill...
Treadmill stops running
I had simillar problem. I have proform 830 QT. My trademill stops after 10 minutes of work out. Everything shuts down and the circuit breaker pops out.
Root cause:- no lubrication under walking belt. Caused the moter to over work (over heat) and hence te circuit breaker popped out to prevent blowing of motor.
Solution:- Apply the lubricant under walking belt and adjust the belt tension if needed.
Back ground:- Contact proform customer service at 1-888-533-1333 (http://www.iconservice.com/proform/faq_tread.html) and buy the treadmil cleaning kit or lubricant kit which comes with a wand for easy application. It may cost you 35 dollars including shipping. If you need to fix your treadmil right away, use NAPA silicon spray 8300. Proform actually tells do not use it as it may damage your belt. However the specialst who came to fix my treadmill just sprayed it and collected 100 dollars. When I called proform they told me lubricating will fix it and its my mistake to not trust them. I guess they knew exactly what they were saying.
Dec 03, 2008 | Exercise & Fitness
Exercise & Fitness Logo
60 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
