Question about Garden
Oil leak kawasaki fh531 - Garden
Oil leak on kawasaki 250 stockman cant seam to find it
Hi, Bob due to the magnitude of yesterday's solar flare my night and x-ray vision optical devices have become inoperable so you will have to be my eyes, to find the source of your oil leak, start at the point where you see oil and trace its path going up and forward, if there is too much oil present then buy a spray can of engine degreaser apply it to the affected area then rinse off with a pressure wand or garden hose, use compressed air to blow off excess water or just let it drip dry, take your bike for a 5 mile ride and check for the leaks. For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
ninja 250 oil leak
Oil Leak Kawasaki Ninja 250r Kick Stand Front Sprocket
2000 2001 2002 2008 Kawasaki KL250 KL 250 STOCKMAN Shop Service Repair...
OEM Parts for Kawasaki
Owner Service Manual Kawasaki Vehicle Manuals
Jan 31, 2017 | kawasaki Motorcycles
How to fix oil leak on kawasaki prairie 300 4x4 at shifter arm on top of motor
Hi, Craig sorry you can't find the first and best tool you ever bought for your Kawasaki despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
03 Bayou Oil leak
Kawasaki Prarie KVF400 ATV Repair Project Part 1
Kawasaki KVF300 Service Manual
Mar 23, 2016 | kawasaki Motorcycles
Oil leak at top of motor by shifter arm on kawasaki prairie 300 4x4
Hi, Craig for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
03 Bayou Oil leak
1996 Kawasaki VN 1500 Vulcan Classic oil leak in the lower back of the engine
Hi, Anonymous external oil deposits fall into 3 categories:
1. WEEPAGE is oil that is sweated pass gaskets, seals, o-rings, and crankcase seams, it's covered by dry dust and is normal for older engines with lots of miles, no repair is necessary.
2. SEEPAGE is the same as weepage except the deposit is wet and confines itself to a specific area, repair is optional depending on the owner's cleanliness criteria, the deposit location and the amount of "DRACHMA" he is willing to part with
3. LEAKAGE is the same as seepage except it is enough to drop to the ground leaving a spot. Repair as necessary.
To find the source of your oil leak, start at the point where you see oil and trace its path going up and forward, blowing baby powder from the palm of your hand will help in those difficult to see areas if there is too much oil present then buy a spray can of engine degreaser apply it to the affected area then rinse off with a pressure wand or garden hose, use compressed air to blow off excess water or just let it drip dry, take your bike for a 15 minute ride and check for the leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My 1999 vulcan 1500 has an oil leak
1998 Vulcan 1500 shifter seal leak
Kawasaki VN1500 Service Manual
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
Sep 08, 2017 | 1996 kawasaki VN 1500 Vulcan Classic
2008 kawasaki mean streak uses a quart of oil about every 800 miles. It's has been doing it for a while.
If it is smoking, then your going to need piston rings.
If its leaking the oil, try to located the leak and buy the new gaskets to fix the leak. If its a side cover gasket, or maybe an o-ring on the oil cap or o-ring on the oil filter cover.
Wipe the bike down or wash it down and look for the oil.
Look near the oil filter and see if oil is leaking, i have saw this several times where the oil filter is leaking, and oil blows down the whole underside of the bike.
The only other place the oil can go is in your airbox. Check to see if your engine crankcase breather hose is blowing by way to much oil and soaking your airfilter. If this is the case then you need to change your oil and filter.
Nov 30, 2010 | 2004 kawasaki VN 1600 Mean Streak
I have a 2000 kawasaki ZR750 with a gas leak
the gas tap has a diaphram and plunger to turn off the fuel when the engine is stopped, this may be dirty, worn or the diaphram gone hard. If dirt has got into the carbs it must have gone through the gas tap.
clean it or get a gas tap rebuild kit
Mar 31, 2010 | 2002 kawasaki ZR-7 S
1994 Kawasaki ZZR-400 Leaks oil and doesnt start sometimes.
that box is called the air box, its where you engine breathes in its air. you say its leaking oil? these boxes are normally a bit oily but only really surface oil. If you can actually see liquid oil you have a problem with your petrol shut off. When the bike isnt running petrol will leak into the engine through the piston. When you start the bike all the petrol mixed with the engine oil will be pumped back into the air box. also check the level of the engine oil, if too much has been put in there then that can also be pumped back into the air box. If the petrol and oil has been mixing you must change the oil as petrol thins the oil and your bike could catch fire, the engine wear will be really bad.
Aug 29, 2009 | 1994 kawasaki ZZR 400
Kawasaki Oil Pump Leak
Bad seal in the pump itself. It is like a weep hole in a water pump. It is letting you know it is time to be replaced.
Jun 09, 2009 | 1996 kawasaki ZX-6R Ninja
2004 Kawasaki Motor Cycle Installed on new head on my 2004 ZX10 - 1000 -Kawasaki . Now have Oil dripping from drain holes in front of the head at tail pipe connection
it may be that your spark plug tubes are leaking they have holes to drain pull off your coil packs and check if they have oil on them
Apr 03, 2009 | kawasaki ZX-10R SE Motorcycles
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
