Nec laptop model
Battrey deat
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
    • 1
Check your laptop's AC adapter. Ensure the laptop's AC adapter is snugly plugged into the port on the back of the . Also, check its connection into either the wall socket or the surge protector, depending on your setup. Make sure the AC adapter is securely in one of these outlets and not loose. Also, if the adapter is plugged directly into the wall, try another outlet. Your existing outlet may be blown.
    • 2
Check your monitor brightness settings. Sometimes these settings get accidentally turned all the way down, which results in what appears to be a dead laptop battery or malfunctioning power supply, but is really just a simple fix. Your laptop has dedicated brightness keys at the top of the keyboard, directly above the numeric keys. Adjust the brightness settings here.
    • 3
Look at the battery indicator light if your laptop appears to be out of battery or suffering a power failure. If it is not flashing or indicating a power problem, your laptop's "LCD closed switch" may be malfunctioning. This switch acts as a sensor which normally judges whether your laptop is open or closed. Sometimes this switch gets stuck in the "closed" position, resulting in the laptop believing it is shut and thus the monitor's back-light staying off. This switch is located right beside either the left or right hinge at the bottom of your laptop's display . Tap this switch multiple times with your finger to attempt to free it up and get it out of the closed position.
    • 4
Consider whether your laptop's battery has completely died and needs to be replaced. Average laptop batteries last for approximately 1000 charges, after which point they either gradual deteriorate and have trouble holding a charge, or simply fail altogether.
Eventually your laptop's battery will have to replaced, and if none of the other troubleshooting steps yielded results this is likely the source of your perceived power supply problems. Flip over your laptop and locate the horizontal outline of the battery, which will be at the top center of the bottom of your computer.
    • 5
Notice the battery release mechanism on the bottom of your laptop, which should be directly below the horizontal outline of the battery. Slide this release mechanism to the left to disengage the battery and gently pop it out. The laptop's power supply may now be replaced.
Posted on Jul 31, 2013
Nec laptop audio driver installation
Go to NEC's web site. Download the self installing driver specifically for you model and click on the driver when downloaded. Job done.
Jan 08, 2015 | NEC Computers & Internet
Nec laptop sound problem
Try installing the latest audio driver.
You can download the audio and device drivers from the NEC WEB site.Please click on this link and select your model computer/notebook and theWindows drivers you require :-.www.nec.com/global/support/downloads/index.html
Jul 26, 2012 | Computers & Internet
Hi i have come in to work and booted the pc and it didnt come on i have looked at the board and the little green light next to the seamen battrey is very dull and while its like that it will not boot and...
hi
i am not certain, you are referring to the NEC notebook. if so, try booting up with the AC adapter only
what model and type is the computer ?
if you are in North America, i can recommend you to a battery store near you.
Follow instructions:
1) make sure computer is off. remove the battery
2) power up the computer with AC adapter attached only
3) if it does boot up, shut it down.
4) re install the battery and boot it up without AC adapter
if the notebook does not boot up, then yes, you need a new battery for it
if the batter is 2 years old or more, you need new battery
send me 4 thumbs up please.
Jun 06, 2011 | NEC Computers & Internet
Were can i find nec driver for my laptop model of my laptop board is PC-LL770FG
You can download drivers from the NEC WEB site. Please clickon this link and select your model computer/notebook and the Windows XP orVista drivers you require :-.www.nec.com/global/support/downloads/index.html
Jan 25, 2011 | NEC Laptop Motherboard (1580262530)
Need a back up replacement batt for AS5534-1121
Hi Roger,
Thank you for contacting Fixya. This is Anil.
I understand that you want to know the Battrey model number for Acer Aspire AS77362 and AS 5534-1121.
I will be glad to help you with it.
Roger, you can find the Battrey part number and Brand name from the battrey lable itself. Remove the battrey from laptop and check on the sticker of the Battrey. As far as store, I would advise you to contact MundoCorp at www.MundoCorp.com or call them at 1865-940-5040 between 9:00 am - 5:00 pm Mon-Fri EST. Please find other stores below:
Capital Data - 1800-999-4409
All parts for new and old units www.capitaldatausa.com
Kahlon 1-800-317-9989
Notebook parts www.kahlon.com
Tiger Direct - 1-800-8300
Acer Direct Phone : 1-888-278-7500
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you
Regards,
Anil.B.R
Jul 18, 2010 | Acer Aspire One PC Notebook
Please give me address of vga drivers for nec versa pro vy22s/rf-l laptop
As I don't know the country the laptop if from, and NEC doesn't have this model mentioned on their support site, it was probably marketed under another model number. So, this may take a little bit of hunting on your part. Here's the link http://www.nec-computers.com/support/ then, on the left under Select your NEC product heading, expand Notebook, start in the Discontinued Products section, I would either start with the Premium or Premium with LAN - each option will take you to a webpage, that shows specifics about laptop. Find a laptop with the same spec are yours, but more importantly video card model that yours has. Click the Downloads link (in blue) Only download the video card drivers. You didn't specifiy O/S or anything else. If you're not sure of your laptop video card - either look in the BIOS or it should show the model when you first power on. You may need to go in to the BIOS to disable the Show Logo (or something similar) option.
If all else fails, http://www.nec-computers.com/support/support_nationalcallcenter.asp ask support if your laptop was/is marketed under another model number so you can download the drivers.
May 08, 2010 | NEC Computers & Internet
I havan't a nec model laviec lc 500/3 display driver
Have you tried the NEC's website? I think they should provide all the software/driver for make the laptop working. Feel free to visit digitalsupporttech for getting help.
Aug 16, 2009 | NEC LaVie S LS900/8E Notebook
Where did i can find driver package of a NEC VY22X/RX-L i lost my cd drivers .. plz help me.. tnx for advance
You download the drivers from the NEC WEB site, make sure you select your model laptop/computr and the correct XP or Vista version of the drivers.
Use this link :
http://www.nec-computers.co.uk/support/
Apr 01, 2009 | NEC Versa FX Notebook
Constantly running
HELLO. FIRST UNPLUG IT. THEN TAKE THE BATTREY OUT. THEN WAIT 15 MINS. PUT THE BATTREY BACK IN. AND PLUG IT IN. AND TRY TURNING IT ON.!! AND SEE WHAT HAPPN'S. LET ME KNOW.!!! GOOD LUCK!!!!
Jun 19, 2008 | NEC Versa LX Notebook
Computers & Internet Logo
David Payne
David Payne
