Question about Rae Systems QRAE Plus Confined Space Gas Detector 028-1112-010
Oxy zero drift - Rae Systems QRAE Plus Confined Space Gas Detector 028-1112-010
WHAT IS THE RED BUTTON FOR ON A 4001 MICRONTA DETECTOR AND DO I NEED HEAAD PHONES FOR IT I BOUGHT IT AT A GARAGAE SALE
The red button is for "auto tune", used to return the meter to zero when it drifts. It is first set to zero with the coil in mid-air, using the Tune control.
There is a built- in speaker but plugging in headphones will let you hear more clearly in noisy environments. It's more useful that way.
Aug 10, 2017 | Vehicle Parts & Accessories
Steering drift it wanders
If this is a zero turn machine you can adjust the drive control levers and tracking so that the machine will track straight rather than go to one side or the other. There are adjustable links at the bottom of the control levers between there and the transmissions that can be adjusted in order to fix your problem.
Feb 06, 2016 | Garden
Just bought a syma s33 and it doesnt seem to go in a forward direction just goes up and drifts where it wants
You need to Neutral (ZERO) the Controls before flying. One additional item to take into consideration is WIND... Many of these smaller units will not fly on a windy day. My first one would be ZERO in a 3 knot wind..
Jan 03, 2015 | Syma s33 3 channel rc helicopter 2.4ghz...
Why am i getting engine code p0421 on this 2002 mitsubishi lancer?
this code is lazy cat (or weak or dead)420's are very hard to diagnose
here is the order.
1: NO EXHAUST leaks near any oxy sensor. zero, (cracks, or gaskets) any where near or upstream of any oxy sensor.!!!
2: Engine runs perfectly CEL out running and no stored or live DTCS (besides 421) and engine holds closed loop at hot idle and light flat cruise, steady right foot, if not , the CAT gets punished.
3: good front oxz sensors, a mUST.
4: AND 2nd last , new rear cat sensors (421s come from this sensor)
5: a NEW cat.
that is the crash course, can do 100s pages.
but no. just 1.
Jun 28, 2014 | 2002 Mitsubishi Lancer
How do you pull hub off & change axil seal on cub cadet zero turn mower
Sound its rusted to axle. After remove e-clip from axle use WD-40 on both sides of hub. There small key goes in hub to keep wheel from turning on axle. The WD-40 should work. I've use a hammer on sides of hub not the tire. There spilt bushing on inside of hub, you need break loose. Back and forth works most of time.
Mar 05, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Is diode on delonghi dmx50 supposed to be OL or a resistance through and if so what would be the resistance
Hi and welcome to FixYa, I am Kelly
First off before testing the diode you must disconnect ONE terminal of the diode to properly test it.
This is going to sound nuts but the answer is it should read both OL and ZERO .... The reading is Open in one direction (OL) and ZERO in the other direction. Just swap the test probe leads on the diode. The purpose of the diode is to only allow the flow of energy on ONE direction. So in one direction it acts like a wire (ZERO ohms) and when you reverse the leads it acts like you cut the wire. (infinity or no resistance) If it reads ZERO in both directions or infinity in both directions it is bad.
Just make sure you have shorted across the HV Capacitor several times by holding a screwdriver well back on the handle before even messing with the diode. After you have made sure that the capacitor is no longer charged... test the capacitor by probing the 2 terminals and watching for a brief jump in resistance and then resistance drifts to infinity. Reverse the test leads and watch for the same jump in resistance and drifting to infinity (OL) No Jump in resistance = Bad Cap Also read each of the 2 terminal posts to the body of the capacitor. NO resistance is allowed. Any resistance reading below 240,000 Ohms when reding either terminal to the body of the capacitor = bad capacitor.
ALL TESTS ARE DOWN WITH NO POWER TO THE UNIT! (Unplugged)
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | DeLonghi MW 535 Microwave Oven
Cursor when using Logitech Trackball sometimes drifts up or down
I finally just was able to solve this problem! I saw somewhere that someone had made sure their primary mouse was selected under hardware, which got me thinking. I thought I had seen a second mouse option somewhere. So, I went into my Control Panel > System > Device Manager and click the arrow next to Mice and other pointing devices. Sure enough, there were two listed. A seemingly generic one and my Logitech I've been using. I right clicked on the generic one and chose disable and the drifting IMMEDIATELY stopped. I went so far as to re-enable that generic to see if it was a fluke because it had stopped drifting on its own yesterday, nope as soon as I enabled the generic device, drifting started again. So Happy!!!
Jun 11, 2009 | Logitech Trackman Marble FX Trackball
Logitech zero calibration reset method
Have you tried using the Logitech calibration uninstall tool that erasers all joystick calibration from windows.
Download and run the Logitech Clear calibration (LWS_CLRC.EXE).
The Clear calibration Utility was developed by Logitech to resolve calibration problems with Logitech digital gaming devices.
NOTE: This utility strips all calibration information in the Windows Registry for all gaming devices. This includes any non-Logitech gaming devices that have been installed.
You may also want to uninstall and reinstall the Joystick Software as well. In some cases, if the calibration issue is within a game, you could try uninstalling and reinstall the game.
Please refer to your game manufacturer for instructions on uninstalling or configuring the game.
Note:
This calibration tool specifically mentions the Wingman Joystick, However, it works for ALL Logitech and NON logitech Gaming Joysticks and Gamepads.
Jun 06, 2009 | Apple Logitech Freedom 2.4 Cordless...
Sears did a computer eval on our car and gave us codes only
P0135--OXY SENSOR HEATER CIRCUIT(bank 1 sensor 1)
P0141--OXY SENSOR HEATER CIRCUIT(bank 1 sensor 2)
P0155--HEATED OXY SENSOR HEATER CIRCUIT(bank 2 sensor 1)
P0161--HEATED OXY SENSOR HEATER CIRCUIT(bank 2 sensor 2)
P01132--LACK OF HO2S11 SWITCH--SENSOR INDICATES RICH
P01152--LACK OF HO2S21 SWITCH--SENSOR INDICATES RICH
Here are the code definitions.hope it helps.
Nov 15, 2008 | 1997 Mercury Cougar XR7
Rae Systems QRAE Plus Confined Space Gas Detector 028-1112-010 Logo
667 people viewed this question
Top Rae Systems Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Rae Systems Measuring Tool and Sensor Expert? Answer questions, earn points and help others
