Question about Music
Looking for instruction manual for disco lights fx lab go17mb dmx
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
Just got a Chauvet Trident and plugged it in and the moter tunrs left then right , then stops ? The LED's blink 1 time then that is it ?
The left right motion is when the motor calibrates its position. The unit is then waiting for input... try generating a loud noise... if the audio gain is up and it is configured for manual rather than DMX it should start.
Dec 24, 2010 | Chauvet Brand New Chauvet Trident Dmx-512...
Does the Eliminator E109 Lights have a DMX connector in the back?
This unit does NOT have DMX control It is only sound activated. If you want to turn it on and off under DMX, you will need to use a DMX relay box.
Nov 22, 2010 | Eliminator E109 Mushroom
I looking to have a Chauvet Cyborg light repaired or to find someone who sells parts.
Here is the link for the info you need:http://www.chauvetlighting.com/service-faq.html Hope this helps.
Jan 21, 2010 | Chauvet Dmx 55 Dmx Controller
DMX-55 Chauvet
Try joining www.djforums.com and posting there to see if there are any Spanish speaking members who can help you.
May 22, 2009 | Chauvet Dmx 55 Dmx Controller
Music Logo
22 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
